lug nuts
Old 10-30-2005 | 09:01 PM
asloudasitgets's Avatar
lug nuts
i purchased some lig nuts with the set of my racing hart c4's and they have been turning out to be the shittiest set of lug nuts i have ever seen. They are not only open ended nuts, but are starting to rust and are causing the wheel studs to rust also. I tried to use the stock lug nuts that are obviously closed ended, but they wont clear the center caps.
Can someone lead me towards some rust free closed ended nuts, that would clear the racing harts?
Old 10-30-2005 | 10:40 PM
power-fade's Avatar
Try Gorilla open lug nuts, they shouldn't rust
Old 10-31-2005 | 12:40 PM
StanMan's Avatar
since you have center covers, just tape up the ends or see if the mcgard spline drive covers will work. i had a similar issue with rust and open ended lugs, but my wheels had exposed lugs so i switched to closed ended (long) lugs. mine were cheap generics though, maybe you need to get name brand.
Old 10-31-2005 | 01:07 PM
fsttyms1's Avatar
mcgard and gorilla make good lugs. Ive never had issues with them
neuronbob
23
07-16-2019 11:48 AM
johnalfa
10-31-2015 01:55 PM
lland
10-04-2015 05:47 PM
MilanoRedDashR
09-25-2015 12:04 AM
NetGnome
09-07-2015 09:33 PM
