Leaking Air?
Leaking Air?
a week ago, I filled my two front tires to 35 PSI, I checked it again today and the passenger side tires has lost 15PSI! While my driver side is still 35PSI, my passenger side tire is 20PSI. I just filled it back again.
Anyone have any idea of what this cause may be? I know that my rims are not bent, and I dont have a nail in it.
check the thing in the middle of the valve stem is tight, tire places have the tool,
or you have a nail/debris you cant see buried in the tread
The tire store will take it and place in a tank of water and rotate the tire thru the water- where it bubbles is the leak
Mark it with special chalk pen. Inspect outside- remove tire from rim- remove object and install patch to hole.
Many places do free inspection and even free repairs- otherwise 10 bucks to fix
Or
You have an angry ex ... or crazy neighbor---install a security camera and see which
Or
I got it fixed this morning. All you guys were wrong. It was actually my rims, there was corrosion on the inner lip so I had it re-beaded. The tire guy told me that he doesnt know how long this will last for, becuase the chrome is peeling on the inside of my rims.
