Installing a Camber kit....
trill recognize trill
Is this easy to do, im trying to put on spc front and rear camber kits, any DIY writeups?
How much should a shop charge to install it?
Wars not make one great
I got my rear kit installed at Les Schwab when they did my alignment. They charged me $100 for the labor. I wasn't sure they'd install parts that I didn't buy from them but they did.
I'm not sure how difficult it would be to do yourself but after spending so much time putting on the coilovers myself i was not in the mood to crawl under my car again for that.
I would suggest the ball joint separator because its really hard without it. At first I tried without one and it took several hours and I still couldnt get it off and with the separator it less then an hour.
@ slide or die @
Originally Posted by Split_TL
Its not that hard, it just takes some time and you have to get an alignment after. The only special tool you need is a Ball Joint Separator .
easy method is putting/leaving the nut on the screw so that it sits flush with the end of the screw and hammer it but do not destroy the castle nut (get a reg nut and beat it up) OR
pitman arm puller....this is what you need. advance auto and autozone rent em out for free
nuldabz
09-03-2015 05:49 PM
