How much PSI?
Old Aug 16, 2008 | 03:31 PM
Yoguess's Avatar
How much PSI?
Car is 03TL-P
i know the OEM tires required 32PSI in Front and Rears.
I have replaced my OEM tires with different ones and they are one inch wider than the OEM's.
Should I stay with 32PSI or go up to what PSI??
Old Aug 16, 2008 | 03:46 PM
ScottayHiFive's Avatar
On the tires it should tell you what the max psi it can handle and you'll just have to fill it a lil bit under what the max can hold. Like I fill mines 4 below what the max can hold. Hope that helps you out.
Old Aug 16, 2008 | 04:35 PM
Yoguess's Avatar
on the tire it say max should be 44PSI
so with what you say I should do 40PSI.
cuz if i put 32PSI then the front looks flat cuz of engine weight.
Old Aug 16, 2008 | 04:43 PM
Yea just fill it up to 40 and you should be good.
Old Aug 17, 2008 | 07:19 AM
AMGala's Avatar
Lamborghini Aventador FTW
A good rule of thumb is to fill your tire pressure to 80% of the max PSI rating, see how it drives and then test a couple PSI less and a couple PSI more to see if you like either better.
Old Aug 17, 2008 | 08:50 AM
fsttyms1's Avatar
That is Very Dumb and Dangerous information you just gave out. You do realize that simple driving will raise your psi above Max and can be very dangerous?????
Old Aug 17, 2008 | 09:06 AM
CJITTY's Avatar
Ackniculous One
I agree with Kris, keep your psi between 32 and 36 psi, just play around with it in that range and you'll be safe and determine your level for comfort and handling. to Kris's point, that is why you never check or adjust tire pressure after you have been driving..the psi will rise once the tires are heated up. I got a small air compressor from wal mart that runs off cig lighter and I check and add air when needed in the morning when car is in garage and has not been driven for at least a few hours. but, my pressure has been steady for weeks at about 35 psi on 19" tires. I kept my 17" stock size tires right at 33 psi.
Old Aug 17, 2008 | 04:20 PM
03aspec's Avatar
36 front 34 rear..
Old Aug 17, 2008 | 11:19 PM
Did not know that. My mistake and apoligizes go out to anyone that took my info. Was just giving this info by a friend and thats what i been using for about 3 years or so. So yea my bad.
Old Aug 18, 2008 | 03:09 AM
LeeDan00's Avatar
Volks FTW!!!
yes i agree. you never check tire pressure after you've driven your car or if it's been sitting out in the cold. hot air will increase pressure and vise-versa. i would stay somewhere around 35psi and nothing more.
Old Aug 18, 2008 | 09:27 AM
VoLLy's Avatar
Meridian
35 front and 32 rear for me.
Old Aug 18, 2008 | 09:48 AM
DrTL05's Avatar
3G TL lookin' good
all tires do "warm-up" but when they do, even if they are over the max rated PSI your fine....thats why it says to check them COLD.....not dangerous just give firmer ride. I run mine 4-6 psi below what's on the tire and I'm happy...
Old Aug 18, 2008 | 12:22 PM
Trackruner228's Avatar
I just run them based on whats recommeneded.
Old Aug 18, 2008 | 01:52 PM
01tl4tl's Avatar
the MAX pressure COLD is whats listed on the tire- and that means at max weight listed too
Reduce the weight- reduce the max allowed pressure
Your TL weighs less than the weight listed on the tire
The tire has built in the safety numbers for heat expansion
Old Aug 18, 2008 | 04:52 PM
fsttyms1's Avatar
Best rule of thumb is listed above. Start out at 80% of max and adjust from there to your liking.
Old Aug 18, 2008 | 06:16 PM
01tl4tl's Avatar
COLD tires of course~
meaning not driven more than 1 mile slowly to gas station, or have rested 3 hours or more after drive
Old Aug 19, 2008 | 10:23 AM
goldendragon576's Avatar
TL-S driver
The dealership told me that on a cold tire 32-34 and if you drove it and need to fill up or check it, about 38psi. Once the tire cools off it usually goes down to 33psi. Since I'm cheap and drive to the gas station that still gives free air, I just set it at 38 and fill.
Old Aug 21, 2008 | 10:05 AM
Gee-TR's Avatar
I like 34 and 32 cold
Old Aug 21, 2008 | 10:41 AM
fsttyms1's Avatar
I run mine 38-36 cold on average.
Old Aug 24, 2008 | 12:24 PM
seahawk's Avatar
Yes... I agree with this . First week of August I had my yearly MVI done at the dealer. ( Moter Vehicle Inspection , once a year , required by law and be done by certified mechanic ) Tires on my TL-S are the original equipment. Michelin Pilots P215 / 50 R17 'S . Max PSI rating on these tires is 41. Mechanic set ALL 4 tires at 38.5 PSI . Now , you can very a few pounds either way if you want. Oh, I bought one of those digital readout tire gages. Far better than the old kind. A lot easier to read.
Froid
Sep 27, 2015 06:16 PM
Robospinner
22
Sep 24, 2015 08:47 AM
NBP_BALLER
Sep 23, 2015 08:18 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
cacheflowe
Sep 14, 2015 10:35 AM
