Horrible Drop NEED HELP!!!!!!!!!!!
can someone tell me what i am doing wrong? the fronts are completely slammed and there is a full hand gap in the rears. tein s. techs 1.9" fr 1.7" r. tokico hp shocks.
if any of you guys are local i would appreciate it if you could help.
Sorry. Hmm. The front looks lower than it should be and the rear is quite obviously too high. This happend to the rear on a friends integra, and his dust covers on his rear struts were either on upside down, or not needed for his kit. Try removing them. Take it all apart and be sure its together like it was when you pulled it out.
The fronts should have much less space in between the coils than the rears, they are a much stronger spring because they have to hold up so much more weight. Maybe you have the fronts on the rear and the rear on the fronts?
Originally Posted by 02type-s
Where did you get them, and how is the Tein logo stamped on the spring? Is it straight if you stand the spring up, or does it follow the spring direction? Is it a sticker, or paint?
What about the serial number on the spring, is it horizontal to the ground or does it follow the contour of the coil?
any thing about the strut placement?
Originally Posted by leopwr
Much better........so I'm guessing they were backwards? Fronts on the back and vice versa?
How long does this mod take? Just curious....
Oh and
thanks guys
took me 3.5 hrs
emailnatec
29
Sep 28, 2018 04:27 PM
4drviper
Sep 23, 2015 07:42 PM
Good job...
