help! wheels
Old May 25, 2008 | 06:28 PM
earthbound741's Avatar
Acura Newbe
help! wheels
hey guys, i read the sticky but still am a little stuck. ok so the wheels are Sport Edition E3 http://www.tirerack.com/wheels/Wheel...4x032&code=yes
i got them for free and needed new tires soon so i wanna upgrade.
ok the sub-centric rings with the rims were 73mm outside diameter and 60.06 on the inside. thats because they came of a toyota camry 2007. i have a 99 tl so i got these sub-centric rings:
http://cgi.ebay.com/ebaymotors/ws/eB...222065802&rd=1
if the link doesnt work, the rings are Inner Diameter: 63.90mm
Outer Diameter: 73.10mm
so now comes the question with rubbing, the rim is 8" wide so that makes it 48 offset right? so i probably should be fine... right?
now with the tires, whats the best size to get? i want a comfortable ride.
Old May 26, 2008 | 09:37 AM
fsttyms1's Avatar
ok for starters our car needs 64.1 for hubcentric rings. Yours are too small at 63.9
2nd rim width does NOT make offset. Look at the back of the rim for the stamping that states the offset. Find that and we can help to tell you if it will rub.
Old May 26, 2008 | 10:31 AM
Acura Newbe
this is the only specifications i can find anywhere. im guessing OFF is well, offset?
Old May 26, 2008 | 03:17 PM
Acura Newbe
ill need spacers i think? 5mm should work or larger?
Old May 26, 2008 | 04:49 PM
myron's Avatar
no man that will be hard to fit. if you put 5mm spacers, final offset will be 33 not 43 making it even worse. I think you got that offset thinkg in reverse like any other new person to the wheels. been there
Old May 26, 2008 | 07:07 PM
fsttyms1's Avatar
your offset is a +38. If you add a 5mm spacer you will be a +33 (like stated above) A 8" +38 will really be pushing it and you will most likely rub a lot and you will need to roll fenders and cut tabs and that probably wont be enough.
Old May 26, 2008 | 09:47 PM
02type-s's Avatar
-Arsenic-
What are they? 17s? 18s? 19s? I have to know that to help you.
Does "1670" under size mean these are 16x7??
Old May 27, 2008 | 12:27 AM
jjashaa's Avatar
Avant Garde Wheels
could be 1670 cm.. or 1670mm... haha.. i uno.. im jk.........
<--- running +30 offset with 18x8.5 and rubbing like a group of fat people in a bus...
Old May 27, 2008 | 06:26 AM
Acura Newbe
they are 16". they came of a 07 camry... so you guys prolly think its the best idea to sell them?
Old May 27, 2008 | 12:19 PM
fsttyms1's Avatar
Yes. get rims that fit better and are larger
Old May 27, 2008 | 12:34 PM
jjashaa's Avatar
Avant Garde Wheels
wow.. 16~!!! dude, get something a little larger. if you're not sure. you can get the 3rd gen stockies. 04-06 but ge something bigger than 16.... don't go soo cheap on wheels.
Old May 27, 2008 | 05:29 PM
Acura Newbe
well dude i got em free! so i was gonna throw em on. but looks like i cant!
Old May 27, 2008 | 10:33 PM
02type-s's Avatar
-Arsenic-
16s FTL. Rolling stock would look better.
Old May 29, 2008 | 08:57 PM
Acura Newbe
sold the rims, and getting stock 17s from a friend..
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
GhostTL09
Sep 19, 2015 01:57 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
