Help - Fitment Question
Old Jan 24, 2011 | 10:16 AM
nf3d0149ab's Avatar
Question Help - Fitment Question
One of my friends thinks I'll have fitment issues on the new wheels I picked up.
Specs on the rear: 19x10 +43
Can anyone confirm if I'll have issues?
Originally Posted by KnightRyderV
hope that fits. seems like a high offset for such a wide rim. you may have clearance issues on the inside.
Originally Posted by nf3d0149ab
Really? They came off an 8th Gen accord and they clear the BBK on a 3rd Gen TL.
Where do you think I'd have clearance issues?
it would most likely touch against the coilover. but im not sure since the CL is a little different than my car. ask lippstuh.
do you know the specs of your current wheels? u can plug it into the wheel offset calculator i use and see how much it will change both inside and outside
http://www.1010tires.com/WheelOffsetCalculator.asp
My current wheels are:
18x7.5 +45
It says that it'll be 36mm less [Inner Clearance] and 40mm extended [Outer Position].
Thanks in advance if you can help.
Old Jan 26, 2011 | 05:56 PM
Flipster23's Avatar
C'mon Noah son LOL!
u will get better response from Diddy and those guys or ask Adrian he might kno
Old Jan 26, 2011 | 08:13 PM
nf3d0149ab's Avatar
Well I thought I'd try and get some opinions from the 2nd Gen members but I guess no one knows...
Old Jan 26, 2011 | 11:51 PM
swllen_cu's Avatar
Since the TL and the 6th gen accord have the same platform, that will definitely hit the strut with the amount of camber you'll need to run those wheels. You'd need about an offset of at least +25 IIRC.
When I had 17x9 +35 dropped around 3.5 inches (-3.3 camber in the rear) in the accord, the rim would slightly rub on the strut when I would go up steep inclines.
I plan to go with 18x9.5 +30 for the next set up on the TL.
Old Jan 27, 2011 | 12:43 AM
nf3d0149ab's Avatar
It seems to be mixed input on this which is really throwing me off base...
Old Jan 31, 2011 | 05:30 PM
Flipster23's Avatar
I was just giving u a hard time LOL!
Old Jan 31, 2011 | 11:16 PM
nf3d0149ab's Avatar
Old Feb 1, 2011 | 05:10 PM
duy's Avatar
duy
I run 9.5 +47 in the front with -1.5 camber and 9.5 +50 in the rear with -1 camber.
The front never rubs the strut, but the rear does rub the strut if I have 2 or 3people in the back and I am going up an incline. With 1 person in back, it does not rub.
Old Feb 1, 2011 | 10:07 PM
nf3d0149ab's Avatar
Thanks for the feedback! Much appreciated.
Old Feb 1, 2011 | 10:09 PM
nf3d0149ab's Avatar
I don't usually carry people so that's totally cool with me. I've even contemplated removing the back seat because I just feel like I should hack the car up and experiment.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
