Eibach Pro suspension Kit with 225 50 R17
Bobby G
I am thinking about lowering my car with the Eibach Pro Kit springs. My question is whether I will run into any problems with the size tire I riding on. I have a slightly wider tire on my car then it came from the factory. Factory size is 215/50 R17 I am now using 225/50 R17 size tires. Will I have issues with the tires rubbing, or should everything be fine? Also, what should I expect to pay for installing the springs?
If you are still using the stock rim you will be fine.
you have teh wron offset rims causing that 215 is such a narrow tire it shouldnt rub. If its the rears causing it its probably the bumper tab's
Originally Posted by civic2000
I have H & Rs w/ 17 Konigs )215/40/r17 and they rub. I am sure sure yet where it is rubbing, the fender well or the fenders itself?
Zonian22
11-14-2015 01:20 PM
MrHeeltoe
79
10-14-2015 08:47 AM
Zonian22
09-02-2015 08:19 AM
