Corner sagging
Old Feb 16, 2010 | 09:54 PM
Neejay's Avatar
Corner sagging
I bought the H&R Sport (NOT accord springs, TL specific) springs used, and the Tokico Blues brand new. The driver's side-rear droops now. With the exception of taking that corner out completely, how can I tell if it's the shocks or the spring sagging?
I guess coilovers would be the next step, but I didn't want to go any stiffer than this for daily driving in downtown ATL...
Old Feb 16, 2010 | 10:18 PM
02type-s's Avatar
-Arsenic-
DId you check your alignment specs? Possibly more negative camber on that side?
Old Feb 17, 2010 | 06:36 AM
Neejay's Avatar
hmm...no I didn't. Would negative camber have THAT much effect on the height? Damn...
I guess I should take some pics of it after I get home from work today.
Old Feb 17, 2010 | 10:43 AM
02type-s's Avatar
-Arsenic-
You would be suprised. When I had my Tein springs, one side looked lower until I got the alignment corrected.
Old Feb 17, 2010 | 11:10 AM
rcb2000's Avatar
if the alignment is way off it can look wierd so check it but the shock isn't the issue it as no effect on ride height the spring is weak and that is why it's saging.
Old Feb 17, 2010 | 02:45 PM
Neejay's Avatar
Damn. Guess this is a must then.
Ugh...I hope not. But good point on the shock not affecting height.
Old Feb 17, 2010 | 02:57 PM
fsttyms1's Avatar
What model # springs did you get
Old Feb 17, 2010 | 05:04 PM
Neejay's Avatar
I'm on my phone now, but they are the ones that are TL specific. I don't have the accord springs.
Old Feb 17, 2010 | 05:15 PM
Neejay's Avatar
Part# 50103
Old Feb 17, 2010 | 09:14 PM
fsttyms1's Avatar
Do you notice if you push on the rear on each side if the side that is sagging compresses or rebounds faster or slower than the other side?
Old Feb 17, 2010 | 09:15 PM
fsttyms1's Avatar
one other thing to check is to see if the shock top hats/stoppers/washers are assembled correctly
TLDude876
Dec 28, 2016 03:18 PM
Sep 25, 2015 06:05 PM
Robospinner
22
Sep 24, 2015 08:47 AM
Silverstead1
Sep 17, 2015 06:45 AM
bymotion
Aug 31, 2015 05:00 PM
