Can't find any solid info on these sizes
I'm looking at a set of 18x8 +40 OR 18x9.5 +40
I can't find any 2G TLs with this exact setup. I know I won't have a problem with the 18x8s, but I still would like some pics. I haven't found one 2G yet with 18x9.5 +40 wheels
Does anyone have ANY experience, visually or personally, with fitting 18x9.5 +40 on a 2G TL? I'm not doing 19" because I don't have a lip kit and don't plan on getting one.
I'm not a fan of my wheels tucking too much, I'd prefer flush...but I'm also not a fan of super stretched tires either.
B A N N E D
they where not flush, but the easiest way to visulize with when i had my a-specs with 245's on them, is that the outside of the tire was basically right where the lip goes all the way in, is where the tire sat (and no i did not have to roll it, but felt alot more comfortable, knowing that if something did get kicked up by the tire, it would be able to pass in between the body and the tire
I think I've decided on trying the 18x9.5" +40. I was looking at p.diddy's CL with 18x9 in the front and with a slight roll, it looks pretty good. I saw another member's TL with 18x8 +40 and it's a little sunken in for my liking.
~~~ SKY'S THE LIMIT ~~~
i have 18x8 with a +38 offset running 225/40/18 and it looks and rides great
i have my rear quarters rolled and the tabs cut out
take a look at the pics in my album named NEW RIMS
I'm running 18x8 +50mm with 225-45-18 tire and have rear fenders rolled and tabs cut. I only rub in the rear when I have 2 adults in the rear and the rub is very small. Mostly over large dips in the road. Hope this helps.
yea glad i can help ya----and i feel ya about the camber
i dunno if a camber kit wud help or not
i know that the look i have now on my car is the look ive been looking for since i got my car
happy as hell with it
post sum pics of yer car
And I found this post: http://www.acura-cl.com/forums/showp...5&postcount=56
He is/was on 18x9.5 +35 225/40/18, so I'm assuming (assuming 18x9.5 +40 would hit or rub the struts) that I could just get a 5mm spacer to compensate.
B A N N E D
hmm thanks. I want to use 225/45 instead of 225/40 too, as I don't like the super skinny tire look.
I don't have any recent ones. It's just a TL-S on H&R Springs...nothing special lol
and as far as going with a higher offset and using a spacer to decrease the offset, is that if YOU do get the measurements a little wrong, there is some room you can play with for getting the correct fit (and you can also just get shims/spacer in even smaller offsets too, in like 1mm increments)
same on mine, so very close to the same drop, and as said for mine 245/40-18 with a 45 offset fit on mine without too many issues (and the rolling was only necessary for piece of mind; but then again the tabs had to be trimmed/rubbed, but thats only plastic though, so no worries there
B A N N E D
they are 3g A-specs, with Bridgestone potenza RE960's
and i bet you could even put a 35 offset on there, if you did indeed roll the quarters/fenders, with as said i rolled mine mainly for piece-of-mind more then anything (and i still had room to go inwards also...)
so if i had the 8.5 a-specs i probably could have gotten a 255 on there even
Cool, cool.
swllen_cu's opinion is that the 18x9.5 +40 and 5mm spacers (I found some 3mm spacers) in case it doesn't clear the struts won't look that good since I'm not 2+ inches/slammed.
I think I'm going to go for it anyway though 235/40/18 (should I go with 45 sidewall?) and 18x9.5" et40 (+3mm spacers)
B A N N E D
Cool, cool.
so i would stay just stick with the 40 aspect ratio
also with those spacers (and the wheel selected), make sure your wheel studs are long enough for the lugnut to FULLY engage the threads, and to actually have the stud poking through the nut a little with a couple of spare threads
basically don't want the wheel falling off due to not enough thread engagement of the lug nut/stud
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
