Camber Kit needed>
Old Sep 14, 2008 | 04:26 PM
Jake 6MT's Avatar
Clemson Tiger
Camber Kit needed>
Sorry I'm posting up all these different threads today but I have alot of suspension questions.
After I lowered my car I did not get an alignment since I thought I was gonna sell the rims right afterwards. My front two tires got really bald on the inside which showed me that there was some sort of camber issue. Would an alignment fix this or do I need a camber kit? I have smaller rims coming in later this week so I need to know if I should order a kit or not.
If yes what kit do you all recommend that is not too expensive
Old Sep 14, 2008 | 04:53 PM
jayunsplanet's Avatar
Toe is a tire killer. It can be corrected with an alignment. I'd get an alignment first -- find a place that does free alignments for a year or something so if it turns out you need a camber kit you can install it and bring the car back for another alignment.
I've driven on 3 different sets of tires with -2deg of camber in the rear over a span of 1.5 years with no serious tire wear.
I drove 7 months on brand new tires with -3.2mm of toe on the front right wheel. Inner portion of the tire was bald.
Toe should be between -1 and 1mm. lol.
.02
Old Sep 14, 2008 | 05:03 PM
Jake 6MT's Avatar
Clemson Tiger
.02
Wow this is just the kind of info i needed. Thanks alot. Do you know if alot of places do free alignments for a year? and would they do it if I also added new shocks?
Old Sep 14, 2008 | 05:05 PM
Rajca's Avatar
wham bam thank you ma'am
if you lowered i dought and alignment is gonna help much. ur best bet is to get a chamber kit for the front and rear, then do the alignment, or do what jayunsplanet said
Old Sep 14, 2008 | 05:15 PM
Jake 6MT's Avatar
Clemson Tiger
Would this front kit work ok?
[mod edit -- no ebay links]
and this rear?
Last edited by derrick; Sep 14, 2008 at 08:50 PM. Reason: www.ebay.com/ebaymotors/97-01-Prelude-Acura-CL-TL-RL-TSX-FRONT-Camber-Kit-98-99_W0QQcmdZViewItemQQ_trkparmsZ72Q3a
Old Sep 14, 2008 | 06:26 PM
DC3328's Avatar
Your Garage
go to the black market under sponsored sales, our vendors sell good quality camber kits
Old Sep 14, 2008 | 08:52 PM
derrick's Avatar
A camber kit is required if you are really low. What springs or coilover setup did you end up using? The suspension has some tolerance to camber (I think it can be adjusted by +/- 1 degree) but if you're really low, you will definitely require a camber kit.
Technically, you should get an alignment done about a couple weeks after you have changed up your suspension. That allows to springs to properly "settle".
I agree with DC3328 -- check out what the official vendors to this site -- they'll have what you need.
Good luck with your decision.
Old Sep 14, 2008 | 10:53 PM
Jake 6MT's Avatar
Clemson Tiger
I just used Tein H-Tech's so its not a really significant drop. Those tires might have been getting eaten up cuz of toe and not camber so when my wheels come in this weekend I'm gonna go get an alignment and see if they say I need a camber kit or not
Old Sep 14, 2008 | 11:25 PM
02type-s's Avatar
-Arsenic-
When I was on H-Techs, I didn't need a camber kit. Now when I bought the Tein SS, THEN I needed one lol.
And your problem is a combo of toe and camber. You don't need a camber kit to adjust toe. Camber really doesnt wear tires that bad, but a combo of toe AND camber does. Go get an alignment and have them set the toe. That should solve your issue.
Old Sep 15, 2008 | 12:28 PM
What were your camber specs pre-camber kit install? And what are they now?
Old Sep 15, 2008 | 09:16 PM
Jake 6MT's Avatar
Clemson Tiger
Thanks 02, if you didn't need one on H-Techs I don't see why i would. Rims coming in on Friday
Old Sep 15, 2008 | 10:51 PM
02type-s's Avatar
-Arsenic-
God that was so long ago. I have no clue, all he said was in was still in factory spec. I don't remeber what the readout said.
Now I run -1.5 up front and -1.75 rear camber.
Old Sep 15, 2008 | 11:44 PM
Excelerate's Avatar
Former Sponsor
Ingalls makes good camber kits. The front kit (adjustable ball joint) from SPC and Ingalls are nearly identical, but Ingalls makes a better rear kit b/c it has 2 arms per side to adjust camber and toe.
Old Sep 16, 2008 | 06:57 AM
Jake 6MT's Avatar
Clemson Tiger
^ ok if the guy who's doing my alignment says I need a camber kit i'll come to you
Old Sep 16, 2008 | 10:30 AM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
If your car is drop and the camber is more than -1.0, then most if not all alignment shop will tell you that you need a camber kit!
My last set of tires last me little over 25,000 miles (almost a year and a half) on Tein SS drop almost to the bottom (1 more thread in front, 3 more threads in the back). The front has -1.7/ -1.8 camber, the rear has -2.1/ -2.3 camber. No camber kit is used. I realize that I can get out more miles if I have camber kit but rotate the tires and alignment every 3,000 miles help tremendously in keeping the tires last that long.
Old Sep 18, 2008 | 05:35 PM
CJITTY's Avatar
Ackniculous One
When I first put my HR Sport springs on, I did not need a camber kit. Now that the springs are 100% fully settled, I fell out of acceptable specs in the rear about 2.5 years after getting the springs on. So, I got the Ingalls 38720 rear kit and it took care of my rear camber issues and the rear kit also slightly helped the front wheels to be better within spec
Old Sep 18, 2008 | 09:24 PM
Jake 6MT's Avatar
Clemson Tiger
Ya I've heard alot of good things about Ingalls kits if I do have a camber issue
Old Sep 19, 2008 | 07:02 AM
fsttyms1's Avatar
Toe will wear tires 10x faster than camber. If he lowered it and has wear on the FRONT tires its TOE which an alignment will fix He needs to go to an alignment shop, have an alignment and get teh specs. Ive had 2.2 on the rears (on other cars) and they dont wear funny at all. Ive got 1.something on the rear now and never have any funny wear (running H&R sports)
Old Sep 19, 2008 | 07:38 AM
AMGala's Avatar
Lamborghini Aventador FTW
The rear toe can't be corrected with the SPC kit?
Old Sep 19, 2008 | 05:29 PM
Excelerate's Avatar
Former Sponsor
The stock rear arms has some adjustment but it's minimal. The SPC rear kit only adjusts camber, not toe.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
