Attention TEIN SS-P OWNERS! Evening the ride height?
Hey guys,
I have a quick question. I recently installed my suspension and I've meticulously measured the ride height numerous times. The front shocks are even but in the rear, there is an obvious error. The rear right passenger size is slightly higher than the rear left passenger side. I checked all four tire pressures to ensure that they were the same and I adjusted/remeasured the height at least 3 times already. And yes, this was all performed on level ground. Has anyone experienced this problem?
Thanks in advance!
Thanks in advance!
I have the same probelem with the passenger front and rear. It probably settled more on the left then the right side. I don't think there should be a problem with the ride. Measure the diff and adjust accordingly. Good Luck! I adjusted crazy times.
08 WDP TL-S
Originally Posted by Omnislash07
Hey guys,
Thanks in advance!
Thanks in advance!
Omnislash07:
i think i m going with the Tein Basic or Tein SS??it there any problem?
08 WDP TL-S
Originally Posted by kRaZy_TL
I'm going w/ the Tein Basic Coilovers at the end of the month when i get paid!! =) I've heard good things about Teins.
but why dun u choose Tein SS then?
It really comes down to how picky you are about the ride quality. With Tein SS you can adjust the dampening force up to 16 different levels (compression and rebound together). So you can choose how stiff the ride is. If you don't really care for ride stiffness, check the tein basics and see if they float your boat. Oh, look into pillowball mounts, it makes life easier. Good luck!
08 WDP TL-S
is there a big problem about to have pillowball mounts?
08 WDP TL-S
Originally Posted by BlueXTC
hmmm sorry, i don't have teins...i got H&R springs but it seems like rear left is saggin lower than the right. maybe the left spring is shorter than the right one?
Pillowball mounts are optional for the SS.
For the basics, the tein website says they are optional for certain applications. In other words, I'm not sure if you can get them for basics or not.
Cheers,
-DT
Cheers,
-DT
08 WDP TL-S
Cheers,
-DT
Cheers,
-DT
Originally Posted by PDX3.2TL
I had the exact same thing happen to me when I first had installed my Ground Control. The only thing that you can do to insure proper heights on all four corners is make sure your thread count in the front and the rear are the same. Meaning that you may like the front at 3 threads and the back at 5 threads. The springs and shocks will settle in evening out the whole setup.
Best in da Burgh
Hey guys,
Thanks in advance!
Thanks in advance!
same with mine. i've had them on for about 6 months now and they've evened out pretty well. there is only about a 32nd of an inch difference, so not that big a deal.
could it be cause of the gas tank?
if so, try to get the tank halfway full... that way if it's close to empty... the ride will only be slightly higher and if its completely full, it'll be slightly lower than the other sides.
The car is starting to even out after several "spirited" drives. I guess the suspension is still in its break in period. Thanks for the replies!
1999 Acura 3.2 TL
1fatcrxnem1
22
06-01-2018 01:23 AM
09-14-2015 10:48 AM
