Accord lower tie bar
quick question, i was just looking around on the internet for suspension parts for my 99. will a 99-01 accord v6 lower tie bar fit our cars?
haha, yea shoulda realized that since it didnt have dual exhaust. im going to take a look under there later to see if its possible. so do we know if it does or not? thanks
well i took a look at the car today, and it looks like itll fit. i just compared the picture above to my car and it is pretyt much exact. i guess ill be the monkey and try it and hope it fits. that same one in the picture is pretty cheap so...
In 702, 808 in Dreams
I thought there was a member that already did this mod? The accord one does fit from what I remember from that post. You need to get a major alignment after since it bolts to the toe adjustment bolts. I remember the member was saying to make sure you alight it right after because his toe was completely off. This bar is suppose to make the rear suspension response more. It should fit if I recall correctly. I just never did it cause my alignment cost more than the bar. haha.
-Arsenic-
yea sorry i make alot typing mistakes.
when i installed the bar i did feel a little more stiffness.
and really just on turns...i remember driving it hard on some roads around work...and it felt a hair more solid. nothing big.
can u anyone here help me with my steering rack install?
Low and Slow
Lamborghini Aventador FTW
slvrcrunch, have you upgraded your rear sway bar? If not, you should do that first. And if money is an issue, you can get a RSB for the 3G TL-S from the dealership. It will fit (you will need new bushings and brackets also) and it's a good improvement over stock.
