Windshield wipers
Old Mar 11, 2015 | 10:42 AM
00RubieTL's Avatar
Windshield wipers
I have a 00 TL and the passenger side windshield wiper nut/bolt always comes loose and makes the wiper arm get trapped under the hood of the car. Has anyone else ever had this issue before? If so how do you fix it? I always have to tighten it up every time it rains.
Old Mar 11, 2015 | 12:26 PM
TLer trash's Avatar
The wiper arm may be worn or stretched where it goes over the wiper pivot. You could try using a washer under the nut which might let the pivot pull deeper into the arm. Try an 8mm washer, but you might have to center a 10mm washer over the stud to allow the pivot to pull deeper into the arm. If not, replace the arm.
Old Mar 11, 2015 | 01:22 PM
fsttyms1's Avatar
Is the nut physically getting loose? Have you tried loctite? ^
Old Mar 12, 2015 | 01:28 AM
Skirmich's Avatar
I would locktite-the-shit out of the nut.
Old Mar 18, 2015 | 10:40 AM
00RubieTL's Avatar
Thanks for the quick responses guys! The nut is loosening up every time I use the wiper. I tighten it like a mothereffer, then its loose again after 5 mins of usage. I noticed that the nut is alil stripped now also, I will try a new nut and see if it works.
csmeance
Jan 7, 2026 06:25 PM
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
rhdune16
Sep 28, 2015 11:31 AM
