Windshield Condensation
Old Sep 13, 2008 | 10:36 PM
thom430's Avatar
Recently acquired a 03 TL. I didn't know much about Acura but I have fallen in love with this car. Only problem that is that at night, even with the defrost off, I seem to have some leak by to the windshield defrost duct regardless of how the AC is set. This causes condensation on the bottom of the windshield and is especially annoying at night.
I don't even want to think of digging into the dash of this car. Has anyone else experienced this problem?
Thanks,
Tom
Old Sep 14, 2008 | 09:13 AM
Rajca's Avatar
wham bam thank you ma'am
u sure its not the diff. in temperature thats inside your car and the outside temp? when i get in my car in the morning my windshield and rear window have condensation on them
Old Sep 14, 2008 | 04:23 PM
larrydiesbach's Avatar
7th Gear
I have seen this happen before
Does this only happen when its warm outside? if not you could have a small leak in your heater box, or perhaps a very small air leak at the bottom of your windshield allowing air to escape in to your car. And with a pin hole in your seal you might not be able to tell it, because of the "Foam Dam" that is between your dash and where the urethane sets.
Larry Diesbach
15 Years NGA Certified Technician
Old Sep 15, 2008 | 11:24 AM
thom430's Avatar
Thanks for the reply, I live in Louisiana and it's always warm outside except for when it's hot outside.
There is cold air from the AC always blowing on the windshield. The condensation is on the outside of the windshield. I can even see the vent guide design transferred to the windshield. I've tried all modes of the AC/defrost control and it appears I have a continuous flow from the defrost.
I've also notice the defrost button has yellow lettering while all the other lettering on the other buttons is white. Is this correct?
Old Sep 15, 2008 | 11:37 AM
achen0122's Avatar
yes, the button should be yellow
Old Sep 15, 2008 | 11:55 AM
7th Gear
Condensation
Oh ok so this condensation is on the out side of the windshield. have you ever tryed Aquapel or rain X on your windshield, it might help eleviate the problem
Larry Diesbach
FixMyWindshield.com
Old Sep 15, 2008 | 01:00 PM
rob-2's Avatar
This is normal, I get this too when I blast the A/C and it's hot/humid outside.
Old Sep 15, 2008 | 04:08 PM
fsttyms1's Avatar
Make sure the Recirculate button is set to OFF. Also use the defrost button and make sure it turns on the AC it will eliminate that from happening.
Old Jul 14, 2013 | 08:54 PM
Phillip864's Avatar
5th Gear
Wish that last post was correct, unfortunately it is not, at least not on our 2004 TL. Tried all combinations with no change in results. I think this may be something we have to live with.
Any resolution to this problem?
Old Jul 16, 2013 | 11:06 AM
TLer trash's Avatar
It's a normal condition in hot, humid weather. It's just like a toilet tank sweating. Just use your wipers.
Old Jul 16, 2013 | 04:00 PM
3.2TLc's Avatar
Yeah Phillip864, don't sweat the petty stuff ! It'll be ok with a swipe of the wipers !!!
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
rhdune16
Sep 28, 2015 11:31 AM
rockyboy
Sep 17, 2015 02:37 PM
