whining noise from engine
Old Sep 1, 2010 | 03:50 PM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
just the other day i ran my car almost totally empty past on a lil roadtrip and i started noticing since then my cars been kinda sluggish until i give the gas like half way then i can feel the car pick up.
and when starting my car on a cold start like after 8 hours or so (not even that cold its like 60 degrees fahrenheit here) and after waiting like 3 to 4 mins for it to warm up i try giving a tiny bit of gas not more then 1800 rpm i notice a lil bit of a whining noise from the engine and sounds like shit.
ive done seafoam and sparkplugs few months ago. i got a new intake manifold on. and new intake filter
i still need to do timing belt and valve adjustment. im at 85k miles
do you guys think i could have messed up something by running it past the empty mark?
Old Sep 1, 2010 | 04:34 PM
fsttyms1's Avatar
if you hear it from your motor you didint cause it from low fuel. Where is it actually coming from? Alt? Motor? Intake? Trans?
Old Sep 1, 2010 | 09:36 PM
kdawg8526's Avatar
update even when warmed up after a highway drive i can still hear it i will open the hood tommorow morning and try to figure out where the noise is coming from
Old Sep 1, 2010 | 10:33 PM
gold2003tl (90)'s Avatar
2003 TL-p
sometimes my tranny would make a slight whining type of noise before it got warmed up, which was maybe 1/4 mile at most before it went away. its always made this very slight wining noise, i consider it normal. but, if it is whining all the time thats not good at all, my old tranny would have a slight whining noise to it all the time shorty before it was replaced. i just consider a very short warm up whining from the trans kinda normal, like the first one or two gears shifts, after that it should be gone. but with this 98-100 degree heat iv had this whole week my car is doesnt need to warm up lol.
Old Sep 4, 2010 | 01:19 AM
kdawg8526's Avatar
i checked the sound today sounds coming from tranny area and timing belt area.. i thinks it might be the belt tensioner making noise because i still have to do my timing belt service im going to do timing service within the next week
but im also thinking it could be my tranny because i only hear the noise in park and neutral and i barely get any throttle response under 2000rpm when in higher gears like 3rd, 4th and 5th
iCrap
Sep 11, 2015 06:21 PM
nash3222
Sep 10, 2015 09:46 PM
Mike Bertram
Sep 10, 2015 09:27 AM
dlknight
Sep 3, 2015 07:54 PM
