Where is the main relay or fuel pump relay?
Old Mar 29, 2012 | 08:30 AM
zmwang's Avatar
It's a TL 2000. I've being looking for all over here and the Web, I can't find any picture or hints about the location of the main relay ( or fuel pump relay, are they the same)?
Anyone can help here? A picture with some red circles will be good.
I searched the underneath of dashboard at driver side, and the hood near the driver side. I can't find anything looks like the main relay to me.
Old Mar 29, 2012 | 09:12 AM
Skirmich's Avatar
The Fuel Pump works on the PGM-FI Relay! Uploading a Pic!
Old Mar 29, 2012 | 11:05 AM
zmwang's Avatar
thank you. That black box does not look like those on the Web.
I will check it out tonight again.
Old Mar 29, 2012 | 02:09 PM
victus1's Avatar
Yes, it's the black box. Good luck pulling it out of that metal tab. Pulling the circuit board out of the box was a lot easier for me. While your at it, make sure you re-solder all the connections because they are known to be bad and cause problems. You don't need to suck out the solder already there. I took out the board for that reason.
Old May 18, 2025 | 03:36 PM
Tarwheel's Avatar
Like this but start relays
this a a good diagram for fuel but how about one with the 43 starter relays? I’ve pulled them from all over the car but can’t seem to find the one that makes the car start
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
