Where is the main relay or fuel pump relay?
It's a TL 2000. I've being looking for all over here and the Web, I can't find any picture or hints about the location of the main relay ( or fuel pump relay, are they the same)?
Anyone can help here? A picture with some red circles will be good. I searched the underneath of dashboard at driver side, and the hood near the driver side. I can't find anything looks like the main relay to me.:whyme: |
1 Attachment(s)
The Fuel Pump works on the PGM-FI Relay! Uploading a Pic!
Attachment 51226 |
thank you. That black box does not look like those on the Web.
I will check it out tonight again. |
Yes, it's the black box. Good luck pulling it out of that metal tab. Pulling the circuit board out of the box was a lot easier for me. While your at it, make sure you re-solder all the connections because they are known to be bad and cause problems. You don't need to suck out the solder already there. I took out the board for that reason.
