Where is the Bank 1 O2 Sensor?
Old Mar 18, 2007 | 08:55 PM
cam99's Avatar
5th Gear
Where or which is the Bank 1 O2 Sensor? on a 99 TL
Old Mar 18, 2007 | 09:08 PM
fsttyms1's Avatar
its the front O2 sensor. Its located on the exhaust pipe just past where the 2 merge together. the bank 2 or rear one is on the cat.
Old Mar 19, 2007 | 10:12 PM
Brewgod23's Avatar
I got the check engine light on my Acura TL 2002 on. I took it to the dealer and he said he replaced my Catylitic Converter with a used one. I drove away and the next day the check engine light came back on. PEP Boys told me that the OBD code was P0420. I also made the big mistake to fill up my tank with regular unleaded gas. Could this be the cause? What else might be wrong?
Old Mar 22, 2007 | 05:00 PM
cam99's Avatar
5th Gear
Hope you got a gaurantee on that used cat!
Crappy gas could set it off too, I suppose.
use up the gas get high octane gas and then
I'd try clearing the codes again ....
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
