Wheel Bearing?
Old Nov 12, 2010 | 12:15 PM
Wheel Bearing?
So, my TL has needed tires since I bought it. Finally got some on there yesterday.
When I got it, there was a pulsating noise, sounded like a bad tire, almost like a 4x4 all terrain type sound. Figured that when I put new tires on it, it would go away.
Well, pulled out of the tire shop, and the noise is still there. Sounds like it's coming from the right rear wheel area. Varies with vehicle speed, no difference whether driving straight or turning.
My guess is a wheel bearing.
Thoughts/Advice?
How difficult is a rear wheel bearing to change?
Old Nov 12, 2010 | 01:32 PM
01tl4tl's Avatar
pretty easy--should be in the diy or search for rear wheel bearing and it should pop up
Old Nov 12, 2010 | 02:14 PM
fsttyms1's Avatar
Wheel bearing. Real easy on the rear to change.
Old Nov 13, 2010 | 01:14 AM
MurkyRiversTL's Avatar
COTM Coordinator
https://acurazine.com/forums/2g-tl-1999-2003-98/wheel-bearing-diy-620807/
Old Nov 13, 2010 | 02:33 PM
Carbuff's Avatar
Original Owner / Oct 1998
In my experience a wheel bearing would change tone when loaded (on turns).
Try jacking a rear wheel and listen to the hub with a mechanics stethoscope (or an empty paper-towel tube).
You could also pull the jacked wheel in different directions (left-right) to see if you have a minuscule amount of play...you should NOT be able to feel anything or hear any knocking.
Old Nov 14, 2010 | 10:15 AM
fsttyms1's Avatar
Rear wheel wheel bearing pics
https://acurazine.com/forums/showthr...hlight=Bearing
Old Nov 14, 2010 | 10:53 AM
01tl4tl's Avatar
what did you have to remove to get to that point kris?
iirc the brake shoes are optional to remove in cases where bearing isnt self welding onto the shaft?
Old Nov 14, 2010 | 01:42 PM
fsttyms1's Avatar
Remove the caliper, Rotor and spindle nut. I had to take the parking brake shoes off because i had a frozen bearing. Once off a couple blows with the chisel and it popped right off.
Old Nov 14, 2010 | 08:26 PM
01tl4tl's Avatar
and the spindle nut is on with the big torque --yes?
Old Nov 14, 2010 | 08:38 PM
totaledTL's Avatar
134 ft. lbs.
KB1_EJ6
Nov 13, 2016 09:51 PM
2012wagon
Sep 29, 2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
heyitsvic
Sep 4, 2015 09:38 AM
