whats the problem
Old Feb 7, 2006 | 12:23 AM
SLAMMED_WDP_TLS's Avatar
whats the problem
THis doesnt seem like a tranny problem but I could be wrong. I have had a few start up problem the past month and a half. THe last two days my car have started up nicely. So I was pretty happy bout it. Well Todaym I was going to go my kick boxing class, I felt my car driving wierd.
Symptom 1. All the gears shifts thru smoothly but once I brake and the RPM level goes between 2k and 1 K there is a slight jerk. I try petal to the metal to see how my car would react. Nothing...everything drives fine. Just like how it was for the past 5 years. Then once I brakek and the gears kick down to around once again 2-1K it jerks slightly. The rpm jumps around in the 1-2.2range. I tried both auto and SS. it does the same in both. But when I tried with SS I left the RPM a little higher no lower then 2.5 and it was fine no jerk or jumps on the RPM.
Symptom 2. after driving, I put my car in park. Then it will start to rev by itself, from 1 to 3K and consistent too.
WHAT IN THE BLUE HELL IS WRONG WITH MY CAR!! I hope its not a pre sign of a slip tranny. Well I put the car in reverse and it was fine, NOTHING AT ALL. IT was smooth. ANy ideas. I jsut installed new headers bout 2-3 weeks ago. My car was revving by itself the first day after I install my header but it hsant done it ever since. The car does not rev by itself when I first start up the car. ITs will start doing that after I drive it, doesnt matter how far. PLEASE let me
Old Feb 7, 2006 | 07:46 AM
PenancE's Avatar
Uh Ohhhhhhhh
Old Feb 7, 2006 | 08:58 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
IAC Valve (Idle Air Control)
Glad I caught this before people all jumped on the transmission-is-dying bandwagon. Search the forum for IAC Valve and you'll find lots of results.
Old Feb 7, 2006 | 01:27 PM
BLADE RUNNER's Avatar
02 TLS SSM - Hi Oh Silvr!
Idle Control Valve
The same thing happened to me. It was the IAC valve as described by 03CoupeV6. The dealer has a bulletin on it and it was covered under my 50k warranty.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
