Water Leak
Old Jan 4, 2007 | 08:57 PM
Brent1202's Avatar
Exclamation Water Leak
My 2003 TL-S has just started to leak on the passenger side. Its leaking from the ceiling directly down onto the seat. Its at the gap where the ceiling and frame come together. Can anyone help me out? Thanks, Brent.
Old Jan 4, 2007 | 09:11 PM
TLsMD's Avatar
WINNING
I am assuming no warranty correct?
if yes take it to dealership....
if no make sure you dont have a lemon and make sure there was no previous water damage to the car such as flood damage and etc....
Old Jan 4, 2007 | 09:26 PM
Brent1202's Avatar
No warranty, I think it could be coming from the sunroof but I'm not sure. The material gets wet and it will drip slightly. Its the gap between the windshield and the passenger window.
Old Jan 5, 2007 | 07:26 AM
pmptx's Avatar
Honda+Blue=My garage
If youve had the windshield replaced, it could be a bad job of sealing at that corner
Old Jan 5, 2007 | 09:10 AM
fsttyms1's Avatar
that or a plugged drain hose. watter shouldn't be getting in unless alot of water is getting past the moon roof seal (which it shouldn't be) i would look into that as well. see if its closing tightly and sealing up properly
Old Jan 5, 2007 | 08:17 PM
Brent1202's Avatar
it looks like the sunroof seal it ok. i poured water down the sunroof drain it seemed to be draining ok. it is a used car and im not sure the front windshield was replaced but it doesn't look like it. it rained today and it was not as bad. i dont know, should i take it to the dealor or someone else?
Old Jan 5, 2007 | 11:00 PM
ProvidenceLeaf's Avatar
Back in a Type S
I had the same exact problem in my 03 TL. It only happened when it rained. It was fine in the car wash. Because of that it was hard for the dealer to duplicate the problem. It went back to the dealership 3 times before they figured out it was a small crack in my sunroof under the rubber molding. They had to order a new sunroof. It fixed the problem. it never leaked after that.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
