vsa switch
Old Sep 17, 2006 | 01:47 AM
victorvu's Avatar
vsa switch
ok i got a question for all of you guys. has any of your guys VSA light ever turned on and stayed on? if so does your switch still click or doesnt? i think mines my be messed up thats why im asking.
Old Sep 17, 2006 | 02:07 AM
bkzjimmy's Avatar
NiGhT rIdEr
did u punch the gas? or do anything to make it come on?
Old Sep 17, 2006 | 04:56 AM
chewi's Avatar
i think it means you overworked your VSA system.
did it ever turn off even after u restart the car?
Old Sep 17, 2006 | 11:59 PM
Soseductivesf's Avatar
Mine came on and stayed on when I had my tranny problem. My check engine light came on also.
Old Sep 18, 2006 | 12:12 AM
victorvu's Avatar
my check engine light didnt turn on and my tranny seems fine now. i thought it was my tranny but when i drained the tranny fluid just 2 days ago and put redline in runs great now. i just want to get the VSA light off. can someone disconnect the VSA and cruise control switch and push the VSA and see if it clicks. because mines doesnt click at all anymore. the switch should feel the same as the cruise when you push it am i correct?
Old Sep 30, 2006 | 06:52 PM
MotionEffects's Avatar
Acura TLS are SLOW
Are Both the VSA Activation (!) and VSA Malfucntion lights are on? Mine has been on since spring, and i havnt got around to diag the problem. I hooked up a scanner and it flashed the Code 84. Its one of 3 sensor-yaw, accelerometer, or steering wheel angle sensor. BTW your ordinary OBDII scanner will not work, I used a Snap-On Modis scanner.
Old Oct 10, 2006 | 11:55 PM
seattle dale's Avatar
Both my vsa & cel came on & stayed on. I tried disconnecting the ground on my battery & they still came on. Long story short it turned out to be a bad O2 sensor. These along with other emission parts are required to be warrantied by the dealer to 70k, by the EPA. Dealer has to warranty it @ no cost to you as long as your under the milage stated above.
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
polish_pat
Sep 30, 2015 12:22 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
