VSA light.
Old Feb 25, 2013 | 11:50 AM
hondakid23's Avatar
VSA light.
Hey guys I was going to clean out my IACV and as I was dismounting the air filter and then the throttle body I had issues with the 12mm screw and I have work in about 30 mins so I stopped and put the air filter back on but as i was doing that the VSA light on my car turned on and its on solid.. What should i do?
Old Feb 25, 2013 | 11:54 AM
fsttyms1's Avatar
go back under the hood and make sure you have EVERY thing connected
Old Feb 25, 2013 | 12:45 PM
hondakid23's Avatar
Everything looks and seems connected
Old Feb 25, 2013 | 05:18 PM
3.2TLc's Avatar
If the "VSA" light came on after your work, chances are something was disconnected or loose.
If ya already re-checked your work, simply reset the CEL.
Old Mar 5, 2013 | 09:39 AM
hondakid23's Avatar
How do you reset the VSA light?
Old Mar 5, 2013 | 09:47 AM
mY sLOW UA6's Avatar
^^Unplug the battery for 15+ mins (I think, I know that is how you reset CELs)
Old Mar 5, 2013 | 09:57 AM
ANC297's Avatar
Bonki' Ehrite!
There are 2 connectors that are "similar" and are easily swapped causing the vsa light to come on. I had gone back over my brothers work on his 02 cls a few years back and that was his problem. OP, take a close look at all connectors
Old Mar 5, 2013 | 06:32 PM
hondakid23's Avatar
Ill check it out I think everythings connected right but if not just disconnect the battery for 15 + minutes ?
Old Mar 19, 2013 | 10:44 AM
412KING's Avatar
does any body have a picture that could show what these two connectors are?
Jamus22
Jun 11, 2023 10:08 AM
cycdaniel
Dec 17, 2019 10:58 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
polish_pat
Sep 30, 2015 12:22 PM
