vibration under braking
Old Feb 23, 2006 | 11:12 PM
randomthought's Avatar
rebmeM deretsigeR
Hi. New to the forum, so sorry if i happen to break any rules. I tried seaching, but i came up empty, probably because the keywords i used werent too good. While braking at a relatively high speed, around 65+, i get quite a bit of vibration in the steering column, which i do usually as i get off the freeway. It only happens at a relatively high speed. Low speed there isnt any vibration at all. Any help is apperciated, especially if theres a thread that may already explain this. Thanks.
Old Feb 23, 2006 | 11:20 PM
supremox's Avatar
Same thing is happening to me, I have an 03-TLP and everytime I apply the brakes at around 55mph+ the steering wheel literally shakes.
Does it also have anything to do with the wheels? I change my wheels from 16" to 18" and didn't notice this problem when I had the 16" wheels. Thanks!
Old Feb 24, 2006 | 08:41 AM
phipark's Avatar
Not Asian
Warped rotors
Old Feb 24, 2006 | 08:43 AM
phipark's Avatar
Not Asian
If it had something to do with your wheels, the vibration would occur at acceleration as well. If it's only under braking, 99% of the time, it's warped rotors.
Old Feb 24, 2006 | 08:55 AM
pmptx's Avatar
Honda+Blue=My garage
Nail hit on head
Old Feb 24, 2006 | 09:26 AM
TwanPD4's Avatar
Sowi Roja u tiga now
yep ordered my rotoras cuz of that reason.
my motto upgrade by neccesity
need tires get rims
lol
twan
Old Feb 24, 2006 | 12:46 PM
SwampGas's Avatar
/etc/car
My rotoras I put in a few months ago are (probably) warped to hell and back. I even get vibration and pulsating at slow speeds.
I'm going to take some sandpaper to them when it gets warmer and hope it's just a coating and not the rotor itself.
Old Feb 24, 2006 | 12:47 PM
fsttyms1's Avatar
Have you bed them in
Old Feb 24, 2006 | 07:43 PM
rebmeM deretsigeR
Thanks for the help. Now i have a good excuse to upgrade. Ive been readin bout the rotoras, but ive seen that some people have had problems with them warping. Ive been thinking about brembo blanks or rotoras with axxis ultimates myself. Thanks again for the help, even if the answer was kinda obvious
Old Feb 24, 2006 | 10:51 PM
SwampGas's Avatar
/etc/car
Of course.
Old Feb 25, 2006 | 10:20 AM
optomos's Avatar
I=X - optomos
Looks like you have an uneven surface (transference of pad material to rotor unevenly or uneven wear on surface) of your rotors. Mine pulsate crazzy like that, to at slow speeds.
I think you best bet it to have them turned and use another pad or have the rotors cryo treated after turning them,
What pads did you use?
Old Feb 25, 2006 | 01:45 PM
SwampGas's Avatar
/etc/car
Didn't think you could turn slotted rotors.
PRO Satisfied ceramic.
Old Feb 25, 2006 | 04:19 PM
JackDiesel's Avatar
Not to be repetitive, but its definitely your rotors. Same thing happened to me and I let it go for about 3 months until I almost got into an accident because I was feathering the brake so it would'nt vibrate. Stupid thing to do and I realize that now. Spend a few dollars and get cross drilled and slotted rotors. You can save a lot of money by going on e-bay. Thats where I got mine and they make a huge difference
Old Feb 25, 2006 | 09:32 PM
optomos's Avatar
I=X - optomos
You can, its just finding someone who is willing & it might cost a little more. Just call around locally. If they were drilled, then you would be SOL.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
