Very odd engine sound
Old Mar 13, 2007 | 10:48 AM
Eisenhulk's Avatar
MUCH bigger than you!!
Question Very odd engine sound
I think my valves are rattling. Whenever I am gently accelerating, I can hear a noise coming from, what I think is the engine. It sounds like metal bearings being turned inside a tumbler. I know this is a weird description, but I can't think of anything better. It's almost a rattling of some sort. Like I said, it's during light acceleration and also during light shifts from 1st to 2nd, 2nd-3rd, etc.
Help would be greatly appreciated because I am completely dumbfounded.
Old Mar 13, 2007 | 11:11 AM
taikoboi's Avatar
6th Gear
I'd definitly take it to acura to check it out and hopefully covered under your warranty.
Old Mar 13, 2007 | 11:13 AM
Eisenhulk's Avatar
With 139k on the odometer, Acura is not going to cover it. I can dream though....I'm hoping this is something that can be diagnosed on the board, then I can fix at home. I like to avoid the "stealership" at all cost.
Old Mar 13, 2007 | 12:30 PM
acutee's Avatar
did it happen all of the sudden, or it has been doing it , and gradually getting worse?
Old Mar 13, 2007 | 12:32 PM
fsttyms1's Avatar
Sounds like that are very hard to diagnose over teh net. It could be pinging, it could be valves that need to be adjusted, it could also be a spun bearing. You need to locate the source of the sound. Can you hear it while idling?
Old Mar 13, 2007 | 02:31 PM
dreem1er's Avatar
deal with it
i used have a noise like that in my nissan and it was my tranny the thing was gone........it might be a cv though.......when my tranny went on my tl it didn't make any noise like that........just go to a shop and have them check it out........
Old Mar 13, 2007 | 02:39 PM
Eisenhulk's Avatar
Thanks for the responses.
dreem1er,
I don't think it's the tranny. Just had that replaced in July 2006.
fsttyms1,
You can't hear it while idling....just light acceleration and the split second following gear change. It's been doing it now for a while. Just can't seem to figure it out. Maybe the power steering pump bearing??
Old Mar 13, 2007 | 03:31 PM
01tl4tl's Avatar
EH
Did you pull a few of the spark plugs and see if they look fouled?
My first instinct would be to run a can of Seafoam thru it and see what happens
Old Mar 13, 2007 | 03:56 PM
Eisenhulk's Avatar
I haven't checked the plugs just yet. Before and directly after the plugs were changed, I was hearing the noise.
I ran the Seafoam through the car two weeks ago. I just poured it into the gas tank.
Originally Posted by 01tl4tl
EH
Old Mar 13, 2007 | 03:58 PM
fsttyms1's Avatar
The fact that you only hear it while driving makes me think its something mechanical? do you get any noise if you slowly rev it in neutral or park?
Old Mar 13, 2007 | 04:25 PM
Eisenhulk's Avatar
No sound while in park/neutral. Only when I'm rolling along.
Old Mar 13, 2007 | 06:13 PM
fsttyms1's Avatar
Then i would say its something mechanical and not with the motor. Maybe a axle or trans?
Old Mar 13, 2007 | 09:44 PM
Eisenhulk's Avatar
I honestly don't think it's the tranny. It was making the noise before I had the tranny replaced, and it's still doing it. I'm thinking maybe the valves or possibly the p.s. pump.
Old Mar 14, 2007 | 12:32 AM
01tl4tl's Avatar
EH
Seafoam in the tank is not same as Seafoam treatment thru manifold vac line
Sounds like time for the stethascope and jack stands for a listen to everything
Old Mar 14, 2007 | 07:42 AM
Eisenhulk's Avatar
I'm not 100% sure how to run the seafoam through the manifold vac. line....that's why I didn't do it.
I think you're right...There goes half of my weekend. Thanks, man.
EH
Old Mar 14, 2007 | 09:07 AM
fsttyms1's Avatar
Car running, pull vacuum line off (so that its still connected to the motor) and insert into can of sea foam.
While its possible that its your valves, the fact that it only does it while driving leads me to believe its not
Old Mar 14, 2007 | 09:14 AM
Eisenhulk's Avatar
Great! Thanks for the Seafoam tip.
Yeah...I guess you're right. It honestly sounds like a bearing rattling/tumbling around.
EH
Old Mar 14, 2007 | 02:54 PM
fsttyms1's Avatar
Hopefully it isnt a spun bearing
Old Mar 14, 2007 | 10:10 PM
bkzjimmy's Avatar
NiGhT rIdEr
i had the same sound and was my tension pulley. i thought it was bearings.
heres the thread i posted when i had the problem....
https://acurazine.com/forums/showthr...tension+pulley
Old Mar 15, 2007 | 07:43 AM
Eisenhulk's Avatar
Thanks, Jimmy. I'll check that out.
Old Mar 17, 2007 | 03:22 PM
AcuraVibes's Avatar
TeAm InSpIrE
ya i have the same problem now i have a weird rumbling noise coming from my engine. i go it diagnose and they said it can be your ignition coil ($70). so maybe it can be the same for u
Old Mar 19, 2007 | 08:36 AM
mariusz84's Avatar
i have 00 tl with 93k miles, and i hvae the smae thing, but when im in park and accelrate very slowly, it does it too, nad it sounds like its coming from the tension pully, and when you put it is drive when the pully is worm, and keep your leg on the brake, and give it some gass to like 1k rpm, and you can hear that its totally coming from the pully, i think in your situation its the pully too.
Old Mar 19, 2007 | 11:33 AM
01tl4tl's Avatar
This is the time everyone should run out and buy a stethascope, or next time you are at Harbor Freight Tools.
Diagnosing bearing noises and valve rattles becomes a breeze
Old Mar 19, 2007 | 01:00 PM
Eisenhulk's Avatar
I think I'm going to stop by HFT this week and pick one up.
Thanks.
Old Mar 19, 2007 | 01:29 PM
sbuswell's Avatar
I need 2 more gears
I have never heard of Harbor Freight Tools, but I'd be interested in having this tool in case I need it. how much do they cost and where else could I buy one?
Old Mar 19, 2007 | 03:23 PM
Eisenhulk's Avatar
http://www.harborfreight.com/
Old Mar 19, 2007 | 05:30 PM
01tl4tl's Avatar
You can buy mechanics stethascopes with a long metal extension and pointed probe tip for 3 bucks or a little more at most auto parts stores
Old Mar 21, 2007 | 09:31 AM
mariusz84's Avatar
went to the dealer, they told me i don't have an ignition recall, but i did the seafoam, that stuff is amazing, my car stopped idoling rough, and the pick up is faster. i will do it again before i cange my oil and ill add some to the crankshaft. but it makes a huge difference. GOOD STUFF
Old Apr 10, 2007 | 09:42 AM
Eisenhulk's Avatar
Does anyone have the exact part # for the tension pulley? I've been looking on www.acuraoemparts.com and I can't seem to find exactly what I need. I think this is what's causing my mystery sound.
Any help would be greatly appreciated!!
Old Apr 10, 2007 | 11:12 AM
mariusz84's Avatar
this is what i found
http://rep.racepages.com/parts/racep...howdc=true#top
hope it helps
Old Apr 10, 2007 | 11:16 AM
Eisenhulk's Avatar
Thanks, bro. Would everyone agree that this is the part that I'm looking for? Just want to make sure I don't order the wrong part.
EH
Old Apr 10, 2007 | 02:31 PM
01tl4tl's Avatar
EH
Finally tracked down that noise eh!
The safest thing to do since its still a try and see situation:
Kragen or other major auto parts store will let you return item of not
the fix you needed
Sometimes its easier to replace the whole tension than swap the pulley out
Old Apr 10, 2007 | 02:48 PM
Eisenhulk's Avatar
Yeah, I THINK that's the problem. At least I hope so.
You may be right about replacing the whole thing.
Opinions/comments???
EH
the fix you needed
tonio
Feb 5, 2019 05:43 PM
Dec 13, 2015 02:21 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Dunnik
Sep 14, 2015 02:56 AM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
