Valve Clatter
Old Feb 21, 2006 | 08:02 AM
pmptx's Avatar
Honda+Blue=My garage
Valve Clatter
Getting a lot of valve clatter at idle. Any standard causes known?
Oil level is good, just a lot of chattering.
Old Feb 21, 2006 | 08:20 AM
georgy_d28's Avatar
I had that problem and i took it in to get the valves adjusted for $69
Old Feb 21, 2006 | 09:27 AM
NSXNEXT's Avatar
Where did you get that deal? Did they include the free snake oil treatment? From what I can see in the Helms manual, and what's been posted on the board, it's not a simple process.
Old Feb 21, 2006 | 09:29 AM
NSXNEXT's Avatar
You sure it's valve clatter and not the purge control solenoid making noise?
Old Feb 21, 2006 | 09:39 AM
honda_inspire99's Avatar
Skeet Skeet Skeet
adjusting the valves is pretty easy if you know what you are doing with the right tools and time. I do it on my gsr a couple times havn't tried doing it on the TL because there is no need to yet
Old Feb 21, 2006 | 10:01 AM
fsttyms1's Avatar
Was just going to ask the same thing. It sounds ALOT like valves and is only really heard durring idle
Have you looked at the TL and how to do it? Its not as easy and the gsr 4 cyl which is sitting right there on top for you. lots of things have to come off
Old Feb 21, 2006 | 12:03 PM
Skeet Skeet Skeet
yea u right the TL would be harder because of 6 cyl and the more stuff that has to be taken off but the concept should still be the same isn't it...
Old Feb 21, 2006 | 12:30 PM
optomos's Avatar
I=X - optomos
Is the purge solenoid ticking normal or a sign of a bad solenoid?
Old Feb 21, 2006 | 12:37 PM
fsttyms1's Avatar
Notsure if they are teh same but it should be very similar if the gsr is running vtec
fsttyms1's Avatar
Normal.
Old Feb 21, 2006 | 03:13 PM
pmptx's Avatar
So if it is the purge control solenoid (PCS), how would I tell the difference?
and next, is it an issue that the PCS is making a lot of noise?
Old Feb 21, 2006 | 04:06 PM
fsttyms1's Avatar
listen closly. find that valve and listen. that sound is coming from the drivers side close to the firewall
and nope
Old Feb 22, 2006 | 08:49 AM
acurabum's Avatar
Touch the PCS , you can feel its ticking .
Old Feb 22, 2006 | 02:14 PM
pmptx's Avatar
Where is the Purge control solenoid located? I assume on the firewall somewhere, but not sure where.
Old Feb 22, 2006 | 03:17 PM
acurabum's Avatar
Top firewall driver side . You can't miss it .
Old Feb 22, 2006 | 10:19 PM
G20Flyer's Avatar
Really a Nissan guy
Just curious - Honda engines dont have hydraulic lash adjusters?
Old Feb 23, 2006 | 07:07 AM
pmptx's Avatar
Thanks all for the help. Time to get under the hood armed with information.
Old Feb 26, 2006 | 06:11 AM
georgy_d28's Avatar
it was at the acura dealer in ok city when i was going to school...i was expecting a lot more but they told me it only take about 2 hours...and it took about 4 but worth it...quieter and better on gas
Old Feb 26, 2006 | 06:24 PM
ArN 2000 TL's Avatar
Moderator Alumnus
I have the same problem and checked it out tday. Its definately the PCS. Should I change it? That noise sounds horrible from the outside of the car. Plus I only noticed it at idle.
Old Feb 26, 2006 | 07:21 PM
NSXNEXT's Avatar
Yeah it's an easy replacement. And I haven't done mine yet.
Old Feb 26, 2006 | 08:44 PM
Moderator Alumnus
thanks nsxnext. I'm gonna look up the part number for it tomorrow and see how much it is.
Old Feb 27, 2006 | 07:49 AM
pmptx's Avatar
When you find that part number , could you put the site and part number up on this thread so those of us too lazy to look ourself will be able to use your efforts? j/k
Old Feb 27, 2006 | 12:01 PM
Moderator Alumnus
ok, this is the part (referenced as #2)
The part from www.acuraoemparts.com is $38.64. Sounds good I guess. Probably will place the order later tonight.
Old Feb 27, 2006 | 12:03 PM
Moderator Alumnus
Normal.
fsttyms1, i know you said this was normal, but how come it never did it before? I'm not doubting your technical expertise, just curious
Old Feb 27, 2006 | 03:02 PM
fsttyms1's Avatar
I ment normal as in a normal problem. Im only asuming that there is something in side that jsut gets noisy with age. Mine has come and gone acouple times. Usually makes the noise only when cold outside
Old Feb 27, 2006 | 11:24 PM
Moderator Alumnus
ok, I guess I'll wait till warmer weather and see if it still ticks like crazy...if so I'll replace it. I have another noise i am trying to track down...everytime i accelerate from a stop it sounds like motor mounts or sway bar bushings creaking. Its VERY noticeable inside the cabin (sounds like drivers side only though) everytime i accelerate from a stop (either fast of slow).
Old Feb 28, 2006 | 12:30 PM
pmptx's Avatar
Thanks for the footwork
Old Feb 28, 2006 | 03:57 PM
fsttyms1's Avatar
I had a sound that sounded like a bad ball joint or bushing and squeeked and clunked. From inside teh car it sounded like it was coming from the passenger side. I figured it out the other day whn i pulled teh engine out. It was the rear engine mount.
Old Mar 1, 2006 | 06:29 PM
Moderator Alumnus
ah shit I hope its not that. Although i do have a feeling it is one of the engine mounts. My question is this: how can i check? I know i can replace them myself so long as i support the engine, but i would feel a whole lot better if i knew that was definately the problem first
I wish i had the guts to do what you do fsttyms1. During the summer i can cause i wake up the vette from hibernation, but the Acura is my DD all winter and in bad weather. Not to mention I dont have a garage to work in so workign outside in like 10degree weather isn't going to happen
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
