Valve adjustments 2002 TL-S
Old Feb 14, 2009 | 09:55 PM
hwy39's Avatar
4th Gear
I had my timing belt replaced today and they suggested I also have my valve adjusted for a mere $475.00 I didn't think there was any valve adjustments on these cars?? Am I missing something??
Old Feb 14, 2009 | 10:03 PM
Rajca's Avatar
wham bam thank you ma'am
depending on the miles and if u hear any ticking noises u might need the valves adjusted.
Old Feb 14, 2009 | 10:18 PM
hwy39's Avatar
4th Gear
Thanks,
How difficult a job is it to check and adjust the valves?
Old Feb 15, 2009 | 08:49 AM
Rajca's Avatar
about 5-7 hrs depending on your experience and tool availability. i did mine but it took longer bc i went out and had the valve covers painted and had to watch some shows on tv .
Old Feb 15, 2009 | 11:17 AM
01tl4tl's Avatar
its less time when they are doing the timing belt
Always a good idea to have done at 105, most cars are finding a few valves out of adjustment- putting them back in spec raises gas mileage and improves performance
Old Feb 15, 2009 | 11:35 AM
rob-2's Avatar
If you're able do it yourself and pocket the $475. It's about $50 in tools if you dont have them already.
Old Feb 15, 2009 | 10:28 PM
CJITTY's Avatar
Ackniculous One
wait a minute..they wanted $475 for just a valve adjustment?? WTF??
Even one of the ripoff dealerships here in ATL was only going to charge $199 for it...my mechanic did my timing belt service with all OEM new parts, valve adjustment, flushed p/s fluid, and put on two new accessory belts for $591 out the door.
Old Feb 15, 2009 | 11:41 PM
phee's Avatar
I got the Shifts
https://acurazine.com/forums/2g-tl-1999-2003-98/valve-adjustment-diy-progress-643700/ did mine in 3 hours
Old Feb 16, 2009 | 09:58 AM
elroy951's Avatar
8th Gear
99 tl 3.2 70,000 i have top end knock when i start up and it goes away in 15-20 min?
Old Feb 16, 2009 | 04:40 PM
elroy951's Avatar
8th Gear
what is a 99 tl worth exl cond 70,000
Old Feb 16, 2009 | 04:52 PM
fsttyms1's Avatar
Please try not to hyjack the thread. Use this to get a good idea.
http://www.kbb.com/
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
lowgrowl
Sep 26, 2015 05:18 PM
