Upper Ball Joint Question
Old 08-26-2013, 02:29 PM
David1221's Avatar
Hey guys I am going to change out my front upper ball joints. Is there a way to do this without removing the upper control arms or do they have to be removed? Thanks for the help guys.
Old 08-26-2013, 02:49 PM
HairyMonkey019's Avatar
The UCA is only connected to the Chassis with 2 bolts and easy to remove.... Except idk how it is with OEM suspension because I took mine out while my coilovers were still intact.
Nonetheless you will need a ball joint removal tool that you can rent from autozone, OR if you have airtools you can probably do it while the UCA is connected to the car, but I doubt it.
Goodluck!
Old 08-26-2013, 07:15 PM
3.2TLc's Avatar
The UBJ can be replaced while still on the car, with the control arm in place.
It's just a matter of the proper tools.....get a Moog BJ which comes with a grease fitting !!!
Old 08-26-2013, 07:50 PM
03 tls nc's Avatar
Good call 3.2TLc. A bungie cord or some thing to tie the UCA up out of the way might be help full.
jblessing
08-08-2018 09:43 PM
marcelft
07-10-2018 06:17 PM
06TLMatt
10-02-2015 08:14 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Upper Ball Joint Question
