unusual noise when turning...help!!
Old Mar 22, 2006 | 03:43 PM
GOODYGOODS's Avatar
IMP_N_ACC
Ok, Its hard to explain but i will try. I have a 99 tl with 60000+ miles on it. I just recently installed some Megan Headers and i think it is just a coinsidence(ms) but when i am turning i get a rubbing/grinding noise from the front. Mainly when i am turning left but occasionally turning right. I have 18" adr's on it with an offset of +48. My wheels are clearing every thing so i know it is not them rubbing. I am worried that it is the transmission since it sounds like grinding and u can feel it in the floor board and peddles. Doesn't do it going straight only turning. If any one has had a similar problem any suggestions would be wonderful. Thanks
Old Mar 23, 2006 | 01:00 PM
99TLHeather's Avatar
Check the dust shield behind the rotors, they might have been bent towards the rotors. Just bend it a bit away from the rotors.
Old Mar 23, 2006 | 10:22 PM
Comet2404's Avatar
Flyin' and Drivin'
i had all kinds of problems with noises on my old 99's suspension... mainly after I got into an accident. My car would pop, groan, moan, and bitch. It sounded like an 80 year old woman having horribly bad gas while coincidently having a heart attack. Anyways, I put my car on a lift and inspected every single area of that suspension and I discovered that things weren't tight enough, and there was a significant ammount of play. So I fixed that and tightened them up, and I guess my old girl got a pacemaker and started taking beano cause it was as quiet as a church mouse after that!
Old Mar 25, 2006 | 12:18 AM
SenorOmar's Avatar
2003 TL Type-S
grinding noise
I also had a grinding noise, only when making a full left turn, with my '03 TL-S. I'd say it was more a crunchy noise rather than a grind, but it sounded awful. Since it was under warranty, I took in and they were baffled, pulled out all the steering and suspension, and eventually tracked it down to a broken pin in the rack and pin steering. They replaced it and it's been fine since.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
