Type-S ecu into base j32a1 engine???
Old 06-28-2011, 08:09 AM
7th Gear
dbittinger's Avatar
Would it be possible to simply swap out the j32a1's ecu for a type-s ecu from a j32a2 engine without changing anything else? Just wondering if this would be a cheap way to increase performance or if other parts (i.e. camshaft, intake, and transmission) need to be swapped out with the type-s ecu for it to run properly. Thanks for any help!!!
Old 06-28-2011, 08:30 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
No that will absolutely, positively not work.
It will probably throw codes.
The ECU does not provide performance gains, the things you mentioned above do and the ECU helps to control them to provide maximum power.
Old 06-28-2011, 08:31 AM
NSXNEXT's Avatar
Welcome to the board.
Members, be kind to the new guy. Any negative comments about the OP are a no-no.
Old 06-28-2011, 09:02 AM
7th Gear
dbittinger's Avatar
Ok, thanks. I was just wondering because I know the j32a2 ecu moves the redline up something like 600 rpm compared to the j32a1 ecu.
Old 06-28-2011, 09:17 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
because of the cams intake etc!
for you-
get a lightweight crank pulley to get to vtec faster
perform all normal and extra maitenance like egr system clean-TB service- lube throttle cables (few think of that)
valve adjustment if near or over 100kmiles
all contribute to economy or performance- depending on how you drive it
the plugged/clogged egr port system causes more problems than most even consider
on regular cars its not a prob- the TL, its every 75kmiles the system needs a good scrubbing and poking out the passages and ports
Old 06-28-2011, 08:06 PM
Unregistered Member
Karanx7's Avatar
LOOOOO-
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
oyayjoe
01-01-2019 10:17 PM
09-14-2015 10:09 PM
Quick Reply: Type-S ecu into base j32a1 engine???
