Turning Signal Bulb Replacement
Old Mar 13, 2013 | 02:21 PM
FlushTL_S's Avatar
Lightbulb Turning Signal Bulb Replacement
How can replace the tiny turning signal bulb in the corner ? Do I have to loosen the whole headlight ? What screws do I have to take out to change it ?
Old Mar 13, 2013 | 04:38 PM
acutee's Avatar
I believe you have to fish your hand through the wheel well lining. Just remove a few plastic push pins and you can get to it.
Old Mar 13, 2013 | 04:45 PM
3.2TLc's Avatar
To loosen and remove the headlight assembly....the bumper will need to come off first, allowing access to the mounting bolts and bulb wiring connectors for the assembly. The size is 24/2.2 CP.
Old Mar 13, 2013 | 10:40 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Yes just saw it in the owners manual today
You don't need to remove the headlights or the bumper. Pop a few of the clips off and reach through the liner
Old Mar 13, 2013 | 11:13 PM
01tl4tl's Avatar
its a 1/4 turn twist iirc
do both sides as the other will not match color or brightness
and it will burn out soon too
At our cars age its wise to replace all the turn and brake bulbs= 20 bucks well spent
and the hid kit to replace its issues or a low beam bulb goes
59$ www.hidextra.com suggest 5000k color low beams
pozebly
Sep 23, 2015 07:30 AM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
