Turn signals out, head lights work
Old Oct 4, 2007 | 10:43 AM
drhonda2's Avatar
I replaced my radio/cd player with a stock unit yesterday. I put everything back together, plugged all harnesses, and tested. Everything works except for my turn signals. They will not indicate on the dash or work on the exterior. Anyone run into this? Just curious before I start replacing parts. Thanks
Old Oct 4, 2007 | 11:01 AM
Bob_F's Avatar
Did you disconnect the battery for the installation?
If not, I would suspect a blown fuse.
Old Oct 4, 2007 | 11:51 AM
drhonda2's Avatar
Fuse panel was the first place I went. The 7.5a turn light fuse is fine.
Old Oct 5, 2007 | 08:12 AM
drhonda2's Avatar
Just so everyone knows, I fixed it. I pulled the gauge panel off again last night and went over it close to an hour. I found a harness had 2 wires pinched in a metal tab. I pulled them out and wrapped in some electrical tape. Then tested the turn signals, fixed! Moral of the story, take your time with any job.
Old Oct 5, 2007 | 11:25 AM
Bob_F's Avatar
Thanks for the update. And congratulations on figuring it out.
Old Oct 6, 2007 | 04:51 PM
illjuan3's Avatar
explain how you fixed it again you pulled the guage cluster out and two wire were pinched together? How did the wires behind the guage do this on a radio install? Im having turn signal problems thats why i want to know?
Old Oct 7, 2007 | 07:41 AM
drhonda2's Avatar
Not the cluster, the cluster cover. There are wiring harnesses running all over the place. My issue happened to be the one running from the steering column, up and to the right going behind the cluster. Some slack had developed and allowed the harness to sag. Thus getting pinched with the cluster cover tabs.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Ny1718
Sep 11, 2015 09:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
