Trunk won't open
Old Dec 9, 2013 | 03:54 PM
2002tltypes's Avatar
Trunk won't open
Hi new to Acura community- 2002 TL-S suddenly trunk will not open with key fob or with button on drivers door panel. When I hit key fob I hear click in glove box but it doesn't activate trunk release. Thinking maybe fuse? No click in fuse box when door button is depressed. I can't access emergency release through back seat access due to amp being mounted in this area on trunk Any help appreciated thanks Bob from Indy
Old Dec 9, 2013 | 03:56 PM
Amp is mounted on back seat in the trunk covering access point from in the car
Old Dec 9, 2013 | 04:29 PM
Nicks2001tl's Avatar
Welcome to Acurazine!
Old Dec 9, 2013 | 04:32 PM
Here you go!
Old Dec 9, 2013 | 10:14 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Lightbulb Bummer
Welcome
You might still have chance through the subwoofer, you will need to pry the panel that has the BOSE logo and unscrew 4 fasteners that hold the sub.
Hey this might be good security for your sound system.
Old Dec 10, 2013 | 12:01 AM
HairyMonkey019's Avatar
Wow... remount your amp dude, you should have thought about this before installing it there on a car that has no key access for it outside.
I had this problem also, the solenoid for the trunk release is definitely broken and NEEDS to be REPLACED. The fuse is not out. Just to remind you, there are 2 emergency releases for our car: 1 above the latch itself, and 1 above the opening along the passenger back, if you can't access either... ur pretty fucked.
Have you tried removing the passenger seats?
This is what you need. It's an easy install.
http://www.ebay.com/itm/Acura-TL-Trunk-Latch-01-03-Power-Release-Lock-Actuator-OEM-3-2TL-/201001055360?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item2ecc98b480&vxp=mtr
Old Dec 11, 2013 | 05:19 PM
Report back and let us know what you did.
SidhuSaaB
May 30, 2020 12:40 AM
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 21, 2015 08:44 AM
brandnewcolony
Sep 12, 2015 10:39 AM
