Trunk won't open
Old Oct 21, 2005 | 11:01 AM
mp6951md's Avatar
4th Gear
Trunk won't open
I have a problem with my 2001 TL, the button on the driver side door to open the trunk does not work but I can open the trunk just fine with the remote. Anyone have an idea whats wrong. Maybe a loose wire or something?
Old Oct 21, 2005 | 11:08 AM
VITEK's Avatar
Ganji, Want some?
sounds like your trunk lock is on. and i cannot remember where it is... ummm look in your trunk... up by the latch or by the left side of the trunk theres a switch somewhere i cant rememberr where, but its prolly off. help me out if you can guys
WELCOME!
Old Oct 21, 2005 | 11:32 AM
FuzzyNutz's Avatar
There is a "valet" switch inside your glove compartment (on the left side). Idealy it is there so that you can lock up important things in your trunk, flip the switch and lock the glove box with your key, and then hand over the "valet" key to the valet or mechanic and they wont be able to get in your trunk. I'm sure only about 2% of the population actually use this feature,.. but I can understand why it would be handy.
Oh, yeah,.. Welcome to the board.
GaryBear's Avatar
Smile
The trunck lock is in the glove compartment. It is called the master switch in the owners manual. It is there so you can use the valet key and not have anyone able to open the trunk.
Old Oct 21, 2005 | 04:24 PM
mp6951md's Avatar
4th Gear
Thanks for the help everyone, I'll try those things and let you know how it turns out. I'm releived that it could be an easy fix.
Old Oct 21, 2005 | 09:15 PM
sbuswell's Avatar
I need 2 more gears
it is the master trunk switch in the glovebox. open glove box on the left side there is a black button push it the other way and try to open the trunk by pushing the button the driverside door, it will work then.
SidhuSaaB
May 30, 2020 12:40 AM
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 21, 2015 08:44 AM
brandnewcolony
Sep 12, 2015 10:39 AM
