Is the trunk release linked to a fuse?
6th Gear
Can anyone tell me if the trunk release mechanism on a 2000 Acura TL is controlled by any of the fuses?
its electric motor operated,,of course it has a fuse!!
where exactly or tied to what I cannot say
wiring Gurus? help!!
Skirmich to the Rescue!!!:
Tied to "Power Door Locks" < From the Owners Manual Page 301
Circuit Diagram from the Service Manual:
6th Gear
Thanks for the info.
If it is controlled by the same fuse as the door locks then I guess it may be the solenoid that is bad because the automatic door locks still work. The trunk latch is stuck in the open position and the latch mechanism has tension on it so I think the cable is ok. Any ideas? Change the solenoid?
6G TLX-S
First check if there is any power going to the solenoid when the truck switch is depressed. The switch or the wiring may be bad.
I do not think it has to do with electrical!
It is supposed to work independent of electrical power.i.e.
close, and open via the emergency thingy in the trunk you can access by droppiny your rear seat back rest.
Try playing around with the latch part and see if it frees up. Get it to function manually first then bother about the power aspect.
Some oil or wd 40 can be helpfull.
I beleive something mechanically is stuck.
My 01 CL trunk lid button is not working i made sure the valet button is was not the issue i tried both positions and it doesn't work but THE KEY FOB WORKS.. its starting to become a pain in the @$$ that i have to shut off the car to open the trunk... please help me any help any advise...thank you please mention about the fuse too please? is that a factor?
ripit
09-26-2015 06:19 PM
justin.w13.walker
09-22-2015 02:21 PM
