Trouble when starting... sometimes...
Old Apr 18, 2006 | 04:44 PM
theshrink's Avatar
Hi, to start out I have to let everyone know I have searched this problem. So the problem is when I try and start the car, it usually turns on just fine, every so often it will start and the engine revs at about 400 rpms, or so the tach says. It doesn't even sound like the engine is on though. I usually try and start it a few times and I finally get frustrated and give it some gas after a few tries and it'll rev up and stay on. To fix this I tried a few things. First, I cleaned the intake manifold and throttle body. Then I changed the spark plugs. It seemed as if all was well and a few nights later it did it again. So I read that it could possibly be the alternator. So today I decided to take it out and get it tested at Autozone. Low and behold it's good. Does anyone have any idea what the problem could be. Thanks in advance.
Old Apr 18, 2006 | 04:54 PM
acutee's Avatar
Does it happen anytime or when it is cold, or when it is first started in the morning? Sounds like to need to clean the EGR ports. I don't believe it is IAC valve with the way you explained it. IF it is something else, I would expect the problem is more consistent. Maybe someone else can help.
Old Apr 18, 2006 | 05:26 PM
theshrink's Avatar
Well, when I was cleaning the intake manifold, I cleaned the EGR port with toothpicks and carb cleaner. Is that not enough? or...
Old Apr 19, 2006 | 01:25 PM
acutee's Avatar
here is another thread about cleaning EGR
https://acurazine.com/forums/showthr...highlight=port
Old Apr 21, 2006 | 11:57 PM
theshrink's Avatar
bump anyone?
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
