Transmission Fluid
Keep It Simple in
Transmission Fluid
Searched...and found nothing.
Is it bad for the tranny if you change your tranny fluid after a long time like 75,000 miles. Does the tranny fluid flushing mess with an auto transmission due to parts of metal entering the fluid and messing with the tranny. Enlighten me.
we do a simple procedure- its even in the owner book
drain out the approx 3 quarts of trans fluid the trans will give up at one time.
refill it- done. Thats the acura method for normal service
The trans holds more than twice that amount- so you can also do it 3 qts 3 times to remove all the old fluid-
drain and refill, drive 5 minutes, using each gear,-that pushes the old fluid toward the drain, drain and refill- do it again and you are done. thats referred to as 3x3 in the threads here
Use only honda ZR1 trans fluid, the book says if you use Dextron3, (thats what most cars use) `in an emergency` fill, you MUST do the 3x3 method to fully remove it!
honda dealer or import parts store has best price on ZR-1 fluid- 7-9$ per quart
Its easier than an oil change, no filter!
This pictorial indicates there is an ATF filter, #9: http://www.acuraoemparts.com/delray/...All&vinsrch=no
some members that waited until over 60-70k miles, maybe 100kmiles, and then did a full 3x3 ended up with trans failure soon after
At that point there is a lot of sludge, and clutch disc wear, the dirt seems to be holding it together and when removed- you get clutch slip= trans failure
Thats a generalization of what happens but you get the idea
With just the standard 3 qts and done- its a partial dilution but should be ok
as for the `filter` on the parts page- thats not normally replaced on a fluid change, I believe some ziners with shifting problems are removing and cleaning that filter with good results
For the normal service only the fluid is drained and refilled 1 time
it won't hurt your trans to do a 3x drain and fill
1. drain and fill
2. drive about 10 miles
3. drain and fill
4. drive anothe 10 miles
5. drain and fill one last time
you dont want to drive 10 miles- all you need is 5 minutes on local streets, and during that drive you MUST manually shift thru each gear- including park, reverse, and nuetral- plus the drive gears
As you do that- fluid is pushed forward thru the system, out of the torque convertor where most of it lives, and to the drain
Longer drive mixes the fluid new with old-while the intent is to drain and replace it!
Higher miles car sometimes encounter problems after a full 3x3 as their first ever trans service
If you do it every 30k miles- that would be good, but wait till 70k miles or more,,, and you are safer just doing 3
and yes I was referrring to a normal service not needing a filter- none of us change that part out with a trans service, and I never heard of it being done at the dealer on a regular trans service either
You are welcome to change yours- and let the rest of us know if it improves shifting and the work required to reach it
I might learn something new!! (dont tell my wife)
SidhuSaaB
May 30, 2020 12:40 AM
