transmission actin up again
Ya....It's an Acura
im drivin home from the store the other night and after stop at an intersection the car has sluggish acceleration and not so much a slip but a strong shift shock from 1st to 2nd gear, and when i redline it it doesnt change gears but stays stuck in 1st gear
now do these seem like symptoms of an ailing transmission, or just a single part?
because this will be the forth tranny on this tl, and its gettin kinda outta control
any input would be appreciated guys
Sounds like a tranny.Any CEL? When was the last one put in?
Ya....It's an Acura
no the CEL doesnt come on and i had the 3rd one put in at about 142,000
as far as regular driving goes, its fine for the most part except for the severe shock
You redline the TL in 1st gear- with an automatic- that you had replaced many times already?????
And you wonder why there is a problem with them?
How many CVs have you been thru?
And im still on my originals, even with the manual.
I am just guessing that the OP does more than redline the trans in first- something involving nuetral drops and drag racing- only reason I can figure to pull that much rpm in 1st
Ya....It's an Acura
im not vince torreto over here, but everyone just floors it every now and then
why let that 3.2 VTEC go to waste?
i change my oil today and find out that the original owner has never changed/flushed the tranny fluid in his 130,000 miles
what a dunce
at any rate i did that and it seems to drive like a car with 153,000 miles should
thanks guys
what a dunce
thanks guys
joflewbyu2
10-08-2015 11:16 AM
