trans fluid
Old Nov 7, 2011 | 03:51 PM
Dankwgn420's Avatar
trans fluid
how much atf does the 4speed from the 99 hold
Old Nov 7, 2011 | 07:03 PM
01tl4tl's Avatar
do you mean on a single drain and refill?
or to change out all the fluid?
about half the contents are stuck in the torque convertor while the rest can be drained
99 owners- how much is that?
I only know the 5 speed takes up to 3.4 qts on a single drain and refill
Yours should be the same or slightly less
Always measure the amont drained!!
use Honda DW-1 fluid
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
