tranny problem ???
Old Nov 8, 2011 | 06:22 PM
skater316's Avatar
4th Gear
tranny problem ???
When I floor the gas pedal the car starts to jerk and rev on it's own until I let go of it. There is nothing wrong with the gears because if I don't floor it completely it'll run smoothly i just cant put the pedle to the floor or else it just revs on 3500 RPM. Can you help me determine the problem?
Old Nov 8, 2011 | 08:28 PM
stickwithjoe's Avatar
My 2002 tls just did that tonite
Old Nov 8, 2011 | 08:48 PM
skater316's Avatar
4th Gear
i dont think its the transmission....well im praying that its not ha
Old Nov 8, 2011 | 10:02 PM
Yeah I just talk to my friend at Honda he's going to check with the mechanics.....
Old Nov 9, 2011 | 11:15 AM
01tl4tl's Avatar
your clutch packs are almost dead
Engagement takes the most grip- then they stay in gear
but full throttle around 25-35mph,,2nd and 3rd gear clutches will show their weakness
Smell the atf- black and burnt sugar smell?
you are both in need of a trans ,,choices are rebuild yours or a used Odessey trans is an option many are doing now
Old Nov 9, 2011 | 01:01 PM
Well the ATF is still redish but it does smell a little burnt. Also it was a little low not in between the two points (sorry not a mechanic don't know specific wordage). Should I do a flush?
Old Nov 10, 2011 | 02:49 AM
01tl4tl's Avatar
fluid level ck is only accurate at 15 minute freeway cruise- from cold- then ck as between the dots
anything else is a guess
any burnt smell is bad news!!!
If its slipping already no amount of new fluid is going to restore grip
but if you want to change it, use honda DW1 fluid..get 4 qts
it drains between 3 and 3.4 qts, have to measure to refill correctly
Do NOT let anyone hook up a machine and power flush the trans
or that may be the last day it drives!
many use a non honda fluid- kills it fast
Old Nov 11, 2011 | 02:23 PM
So I talked AMMCO here in corpsus christi, Tx and he said following..
17hrs of labor 85$hrly = 1445.00 plus parts.
He said Kevlar parts not needed it's just a marketing tool.
3yr warranty national.
This is on a rebuild.....
My worry is if for some crazy reason he says they have to do a full swapp without internal rebuild then it's really going to cost aloooot more...... Bad thing here in this town I dont know many trustworthy places to rebuild.
Please advise and thanks for any imput.....
Old Nov 11, 2011 | 02:57 PM
jzhu625's Avatar
AMMCO? not worth the time and money
Old Nov 11, 2011 | 04:45 PM
ggaveit2u27's Avatar
new guy
[quote=01tl4tl;13352912]your clutch packs are almost dead
you are both in need of a trans ,,choices are rebuild yours or a used Odessey trans is an option many are doing now[/quote you just sent me for a loop whats the deal with the odessey trans
Old Nov 11, 2011 | 05:18 PM
skater316's Avatar
4th Gear
I just had my oil changed and my car runs great now, faster then ever
Old Nov 11, 2011 | 07:07 PM
01tl4tl's Avatar
Honda oddessey trans fits our engine with a small modification, its a better unit overall and cost less than the 2500 to rebuild, see threads on the subject
only reason they cant rebuild yours is if there is a crack leaking fluid in the case right now
otherwise they take it apart- clean everything, measure to see whats reusable and whats dead--gear wear shaft wear etc and install all the new parts
AA has a bad rep due to their corporate quota and mentality of get it done fast and cheap (for them not you) ,,not done to the very highest standards
Use the phone book for smaller private shops, call private owner type honda repair shops and ask who they use
look in Regions section for ziners near you for referal to good shop
All major name places are daily/weekly/monthly quota based, and must sell and upsell jobs... or lose their job!
aa gets a parts kit from their supplier, which doesnt contain the best parts and clutches,
it has whats cheap for them to buy!
We have an aa manager on here who swears his shop does them all the time no prob
but its not a company wide abilty~
Old Nov 11, 2011 | 07:09 PM
01tl4tl's Avatar
skater- they changed the ATF? how much of it..3 qts or full 7.3
and what exactly was installed for new fluid? honda DW1?
reset a mile meter and track how long this fix last~
Old Nov 11, 2011 | 09:35 PM
Okay will do!!!!
Old Nov 14, 2011 | 10:42 PM
skater316's Avatar
4th Gear
i just went to oil changers got oil change and transmission fluid change, car runs great now, check engin light went off now
Old Nov 15, 2011 | 03:41 AM
01tl4tl's Avatar
what exactly did they use for atf and how many quarts??
if not on the receipt call them or drop by and speak directly with tech, not counter girl
The fluid is pretty important --the TL is very picky
If you found one thats better,,we need to know
If your trans takes a dive in a week--the shop needs to know it put a non-allowed fluid in,,say dextron3
Definetly ckeck the level per book method
15 minutes freeway cruise from cold, get off park safely and ck level `between the dots` at that fluid temp
Indicated level changes with temp
Old Nov 16, 2011 | 12:42 AM
bigwerm187's Avatar
Str8 Home built
Whoooa there Odessey tranny will fit a 2.5 tl... ????
Old Nov 16, 2011 | 10:52 AM
01tl4tl's Avatar
I dont know about the 2.5,,its being used with the gen2 TL 3.2 engine
Old Nov 16, 2011 | 12:07 PM
bigwerm187's Avatar
Str8 Home built
I just saw i posted in the wrong section lol ... The first gen 2.5 uses its own tranny cuz its almost set up like a rwd car
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
