trannie jerking when changing gears
Old Sep 24, 2011 | 02:42 PM
FALFUS's Avatar
Iown an acura lts 2003,my avs and ! lights came on , and my Idle rpm was low so I changed my Idle control valve and the Idle problem is fixed but now the lights are still on and my trannie is making a jerking every time my trannie cha ges gears what the ef is going on? can someone helpme please. thank you all.
Old Sep 24, 2011 | 03:51 PM
01tl4tl's Avatar
get to a parts stores for a code reading- report those back here
IAC- why replaced not just clean?--we are talking about the thing inside the bottem of the throttle body right?
reset the ECU by pulling the CLOCK fuse on passenger end of dash for 1 minute
that makes the system do a full reset-self test and relearn
03 have an `idle relearn` procedure required after ecu reset- ck owner book or search on here for it
Old Sep 25, 2011 | 10:38 AM
918motorsports's Avatar
You should take off the solenoids and clean them out. You may also try some seafoam transtune and then change your fluid.
Yikes
May 3, 2021 04:29 PM
mugen_kid
Nov 13, 2015 10:38 PM
Aleax
Sep 11, 2015 11:31 AM
kuzdu
Sep 10, 2015 08:42 PM
HeloDown
Sep 8, 2015 06:51 PM
