Bad Ballast? Anyone have this problem
Old Sep 27, 2011 | 09:54 AM
myron's Avatar
So I have this problem with my passenger headlight low beam. I don't know what it could be but it's getting on my nerves so I tried searching and I didn't see anyone have a real solution to something like this.
When I turn on the low beams, both headlights turn on fine, same brightness, all is well. Then a short time after that my passenger light turn off. It can be on for 10 min, or it can be on for 30 sec. There is no specific time frame before it turns off. I took the headlight out and I noticed the plug between the ballast and the stock harness is busted. So I took the busted plastic connections off and wired it straight to the ballast. Still the same problem. Last thing I did, was go straight from the battery to the headlight using jumper cables. No relays, no any other electronics involved, just power to the ballast straight from battery and after a few min the light went out again same as before.
Now is it safe to say that this is a problem with the ballast? If not what else could it be?
Old Sep 27, 2011 | 10:06 AM
01tl4tl's Avatar
bulb life is at its end for many of us
do you get a pink or purple tint to bulb at start up?
many many way too many of us are having ballast issues due to moisture gets inside
the housing lens--then drips down and onto the ballast = brilliant design~ (not)
the best way to cure any light prob on our car is with a complete new aftermarket HID Kit,,with 2 new waterproof ballast- 2 capacitor-connector wires and 2 bulbs,,our sponsor www.hidextra.com has it for well under $100 including the relay kit which I suggest as a good plan, gets battery direct power to the new parts
ck their site- look online for their name+coupon codes for 10% more off!
call for best servive and mention acurazine as your referral- let then know their advertising $upport of this site is worth it!
suggest 5000K color bulbs, stock was 4300, 5 has a little more blue that most like for its abilty to light up the reflecto paint in lane markings-road signs etc
Old Sep 27, 2011 | 10:46 AM
totaledTL's Avatar
Originally Posted by myron
... so I tried searching and I didn't see anyone have a real solution to something like this....
Didn't you look in the DIY sticky (lighting section)? https://acurazine.com/forums/showthr...llast+inverter
Old Sep 27, 2011 | 10:53 AM
myron's Avatar
Yea it seems that it's better for me to get a brand new HID kit than a ballast replacement. OEM ballasts are so damn expensive and they don't seem to work very well.
No I don't have pinkish or purple tint to the bulb at start up. it works just fine, looks the same as the drivers side.
So on this site what do I choose: 1999 TL Low Beam 5000K Car has factory HID and it says it's only 59.99? Do they automaticaly know to send all the relays and such?
Old Sep 27, 2011 | 11:06 AM
myron's Avatar
damn I guess I missed that one. I think I will get a new kit, then try and mess around with this stock one. Maybe I could fix it using that DIY and sell it. I think that waterproof aftermarket kit would be better for me considering at am looking at 6 months of winter. Thanks for the link though
jblessing
Aug 8, 2018 09:43 PM
BoricuaTL
Apr 8, 2016 01:08 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
gehrlichman
Sep 22, 2015 10:08 AM
theinsvnity
Sep 10, 2015 10:22 PM
