Torque specs for front axle nut
Old Apr 5, 2009 | 10:56 AM
OntarioTL's Avatar
Now that I have finally recieved my new key lock to remove my winter tires (lost the damn thing after I replaced the upper ball joint), its time to do my front wheel bearings. I've looked all over the place and I dont have the manual. I'm also going to try this hub shark I keep reading about and the possibility to remove the bearing without removing the spindle.
Can anyone help me with the torque specs for the following?
Front axle nut
Lower ball joint
Outer tie rod
And while I'm at it, the upper ball joint just to see if I did it correctly.
Early Thanks
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ellisd03tls
Sep 8, 2015 04:17 PM
NetGnome
Sep 7, 2015 08:33 PM
