Torque Converter Malfunction!
Old Dec 11, 2006 | 11:12 PM
joe80055's Avatar
Hey, I was driving today going about 55-60 mph and the check engine light came on... went over Autozone to get my code read.. turns out to be the Code: P0740. In other words, there's a malfunction in the Torque Converter Clutch (TCC) Circuit. ... Is this a huge problem I should be worried about? I'm not sure if it's a problem in the wiring or the TCC solenoid itself... any ideas anyone?
I have to make the trip back up to RI for christmas break from FL, so would I be in trouble making the trip or should I avoid everything all together?
Old Dec 12, 2006 | 12:13 AM
joe80055's Avatar
Did more searching.... read other posts... I don't understand, the car shifts fine and everything, and yet, everyone else that had the code ended up getting a new tranny
Old Dec 12, 2006 | 01:44 PM
fsttyms1's Avatar
thats what my last failure was
Old Dec 12, 2006 | 05:05 PM
joe80055's Avatar
Well shit. Can't do much but start saving up I guess. This tranny so far only lasted me since August. wtf.
Question... Is it possible that an Acura dealership would install the 5spd (including all other necessary parts) and still warranty it?
Old Dec 12, 2006 | 06:10 PM
fsttyms1's Avatar
That failure isnt teh normal failure we all have. Is there warranty left on it since its only a few months old?
Anf 2nd question. VERY HIGHLY Unlikely
Old Dec 12, 2006 | 06:31 PM
joe80055's Avatar
^ The warranty just expired last week... Even worse, the place I got it from is 1,300+ miles away. Kinda sucks.
Old Dec 12, 2006 | 08:54 PM
fsttyms1's Avatar
Contact them and see if they will work something out? 1 week past isnt that far
Old Jan 4, 2007 | 07:30 PM
mdavisii's Avatar
B93P TL Owner
I was under the impression that the torque converter was not part of teh transmission replacement. Am I not correct on this?
Old Jan 4, 2007 | 07:33 PM
fsttyms1's Avatar
It should be since it can house contaminants that could effect it. Most rebuilders that i talked to replace it while rebuilding them
Old Jan 4, 2007 | 07:43 PM
j2bates's Avatar
Dealer Technician
If it was an Acura reman transmission, the torque converter was replaced with the transmission.
Old Jan 4, 2007 | 09:28 PM
mdavisii's Avatar
B93P TL Owner
Very good to know.
Old Jan 12, 2007 | 05:40 PM
docrob's Avatar
I just got around to checking my CEL since I just got my code scanner in today and have the P0740 now, I had the tranny replaced by Acura 9/2005 at 96,xxx and now have 135,xxx miles. The car seems to run perfect, but based on others experience, maybe it's just a matter of time. I was hoping to have this one last at least a few years or so. I guess I'll have to keep my fingers crossed.
Old Jan 12, 2007 | 05:42 PM
phipark's Avatar
Not Asian
When I threw that code, Acura replaced the tranny.
Old Jan 12, 2007 | 06:16 PM
docrob's Avatar
I don't think they'd replace mine since it's been 16 months since the last replacement and now I'm at 135,xxx miles. Aren't they only warranteed for 12 months/12,000 miles?
Old Jan 13, 2007 | 08:48 AM
docrob's Avatar
What if the newer, post 2/05 trannies now have torque converter problems?
fstttyms1, didn't you have a torque converter problem with the last tranny you had? And now we have a couple more?
After I cleared the code last night and went for a short drive, car was running a little funny. When I come to a stop/slow to almost a stop such as when coming to a stop sign or when parking, the car "shudders" at least a couple times. It doesn't really seem like it's going to stall, but feels like it could almost lead to that if it got worse.
Does anyone know if this code is electrical/solenoid related or more of a mechanical issue?
If I can get time this week I just might take it to the local Aamco that I trust and has done excellent work for me a few times in the past and have them do a free check on it to see what they say.
Old Jan 13, 2007 | 10:55 AM
phipark's Avatar
Not Asian
I don't think that has anything to do with the tranny. If you watch the tach, is it dipping below 750 RPMS?
Old Jan 14, 2007 | 08:10 AM
docrob's Avatar
the tach does dip, but after driving a little more yesterday, it seems like it isn't doing it now like it was. I probably drove 60 miles total and the P0740 code hasn't come back yet. One thing I did notice is that if I give it some gas and let off when driving at any speed, when the rpm's drop from letting of the gas, the tach bounces a little once or twice. I don't know if this was happening before I got the torque convertor code.
Old May 5, 2008 | 03:56 PM
TpSC3crT's Avatar
My car is doing that exact same thing... that codes been bothering me for the past 2months.... hows your car running?
Old Jul 12, 2008 | 12:44 PM
FuriousSam's Avatar
I just got the code last night, how is everyone doing with that code?
Old Jul 9, 2009 | 09:43 AM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I just got that code ALSO and my tranny was replaced in 2005!
It has less then 70K miles on it and I tookd VERY good care of her Changed the fluid every 15-20 K and DID not use SS or abuse her at ALL!
She shifts just FINE and no difference in the way it drives but did throw code P0740
Torque converter clutch and soleniod ciruit, What should I DO?
Old Jul 9, 2009 | 09:56 AM
MurdaZ's Avatar
clear it and see if it comes on again?
Old Jul 9, 2009 | 05:57 PM
ANC297's Avatar
Bonki' Ehrite!
I got that code last June on the 03 and the tranny was replaced under warranty as well.
Old Jul 9, 2009 | 07:50 PM
StonedCL's Avatar
B A N N E D
I cleared the code and also found a ground wire that came dissconnected by the TQQ soloniod.. I reconnected the ground wire and cleared codes drove 5 miles and tranny feel fine just like it did B4 the code came on.. If its a real problem how long till the code pops up again?
Old Jul 19, 2009 | 11:43 PM
slvrcrunch's Avatar
when i first got my car, the solenoid was bad but i didnt know it. drove it down the road and pissed me off a good bit. it didnt shutter or attempt to stall, but in between gears it did jump up about 2500RPM then yank into the next gear.. got that replaced and its been fine since, just a little damga to the convertor itself since i drove it a few miles without the solenoid working properly. no check engine light, shifts pretty good... hope this helps.
knight rider
Mar 4, 2016 08:59 AM
Skirmich
Oct 1, 2015 12:59 PM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Rcelestino93
Sep 23, 2015 10:01 PM
