TOO HOT, NO A/C, Please HELP!!!
Old Jul 15, 2012 | 08:12 AM
charlestonsasha's Avatar
Hello everyone. I have 2003 acura tl, which i bought used last year. Now when it's hot i NEED my A/C((. I think it didn't work when i've bought it, but was too cold to test it((. Well, we were trying to fix it yesterday with no luck. A/c will not take a charge. It will take 150 gramms and thats it. Compressor will not engauge when a/c button is on, no power coming in to a compressor, even after we jumped the pressure switch. BUT you can hear a click when i throw a 12v to a clutch from the battery and it still not taking a charge.
Does anyone know the steps how to troubleshoot the A/C on 2003 tl? I would really appreciate if someone will help me out.
P.S. by the way the was a fuse box replaced under a hood and wires were extended 20 inches(don't now why) and not sure if they were soldered. Is there my be a problem perhaps???
Old Jul 15, 2012 | 11:58 AM
fsttyms1's Avatar
I would start with the wiring that was changed and make sure every thing is connected. Check the fuses as well.
Old Jul 15, 2012 | 12:22 PM
i've looked at fuse box diagram on the cover and looks like nothing related to the a/c in there, i'm i wrong? by the way where is an a/c relay(s) and fuse(s), i don't have a book+plus couldn't find online their locations.
thanks ahead
Old Dec 6, 2012 | 07:12 PM
mrbustrbrown's Avatar
did u ever find your problem?...i had same problem after doing my radiator and found that the wires from the fan on the passenger side lead towards the engine and theres a connector for them...long story short...inspect those wires and push them in to the connector and reconect....did that to mine and the compressor engaged and coooooold air blew...been 2 years now no problems
Old Jul 11, 2013 | 07:52 PM
heybeni's Avatar
im having a problem with my a/c too, it workerd fine but now the fan doesn't turn on, i think it cools but just doesn't blow the air
Old Jul 12, 2013 | 07:04 AM
3.2TLc's Avatar
Hey Heybeni, chances are that the blower fan's wiring harness connector is bad. This is a common problem. Search previous posts for more info. Also, the climate control has a self-diagnostic feature which may help. Check out the fuses/relays for the blower.
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
mlody
Dec 4, 2019 02:11 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
