TOO HOT, NO A/C, Please HELP!!!
Hello everyone. I have 2003 acura tl, which i bought used last year. Now when it's hot i NEED my A/C((. I think it didn't work when i've bought it, but was too cold to test it((. Well, we were trying to fix it yesterday with no luck. A/c will not take a charge. It will take 150 gramms and thats it. Compressor will not engauge when a/c button is on, no power coming in to a compressor, even after we jumped the pressure switch. BUT you can hear a click when i throw a 12v to a clutch from the battery and it still not taking a charge.
Does anyone know the steps how to troubleshoot the A/C on 2003 tl? I would really appreciate if someone will help me out.
P.S. by the way the was a fuse box replaced under a hood and wires were extended 20 inches(don't now why) and not sure if they were soldered. Is there my be a problem perhaps???
I would start with the wiring that was changed and make sure every thing is connected. Check the fuses as well.
thanks ahead
did u ever find your problem?...i had same problem after doing my radiator and found that the wires from the fan on the passenger side lead towards the engine and theres a connector for them...long story short...inspect those wires and push them in to the connector and reconect....did that to mine and the compressor engaged and coooooold air blew...been 2 years now no problems
Hey Heybeni, chances are that the blower fan's wiring harness connector is bad. This is a common problem. Search previous posts for more info. Also, the climate control has a self-diagnostic feature which may help. Check out the fuses/relays for the blower.
SidhuSaaB
05-30-2020 12:40 AM
mlody
12-04-2019 02:11 PM
Biggie_B
02-26-2017 11:14 AM
