TL Pulls to the Left when Braking....
Old Nov 23, 2008 | 09:20 AM
AD123's Avatar
Mine is a 03, 3.2 TL, done 100K Miles. Strange problem - upon Braking the car steering jerks ( about 2-3 cms) to the left, and when accerlated the steering slightly jerks to the right side....
anyone... any suggestions.. where should I start looking..... I hope its just some bolt that is loose and needs to be tightened !!!!
Old Nov 23, 2008 | 09:32 AM
Rajca's Avatar
wham bam thank you ma'am
might be a sticking caliper.
i wish that all of our fixes were as easy as tightening a bolt
Old Nov 23, 2008 | 11:15 AM
01tl4tl's Avatar
ok- make sure the front caliper bolts are all tight!
then proceed to inspect caliper operation and replace if needed
If so, many of us upgrade to Legend calipers for the same price as tl calipers- about 75$ each, rebuilt
01tl4tl's Avatar
how does the fluid look in the master cylinder- ever been changed?
needs to be done every year!!
Old Nov 23, 2008 | 11:23 AM
AD123's Avatar
Let me check the bolts and revert....meanwhile the brake fluid level in the master cylinder is between the Min and Max level, though closer to the Min mark. havent changed the fluid in the last 3 years.....
Old Nov 24, 2008 | 01:23 PM
Edward'TLS's Avatar
6G TLX-S
A caliper may be seized open.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Skirmich
Oct 1, 2015 12:59 PM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
