Tires worn olut on the inside!!!
Old Mar 25, 2012 | 11:02 AM
1st timer's Avatar
UB6IB9
I dropped the suspension using H&R OE springs and my tires are all worn out on the inside and i need to change them. My ball joints also need to be changed. I guess i need a camber kit. My Question is, should i get front and back kits?
Old Mar 25, 2012 | 11:17 AM
1st timer's Avatar
UB6IB9
tires are 225-50-17,cant remember the wheel offset.
Old Mar 25, 2012 | 11:37 AM
fsttyms1's Avatar
Did you ever get an alignment AFTER you lowered it? The OE kit doesnt require a camber kit. Sounds like you need an alignment to get rid of a toe out issue.
Old Mar 25, 2012 | 12:33 PM
1st timer's Avatar
UB6IB9
it has gotten an alignment twice!
Old Mar 25, 2012 | 12:43 PM
1st timer's Avatar
UB6IB9
I always have problems with steering when i have my summer tires on. Car always pulls to either side. When i have stock size tires on like my winter tires i have no issues.
Old Mar 25, 2012 | 03:50 PM
cdn_rider's Avatar
VIP TL
then your sumer wheels need balancing.
Old Mar 25, 2012 | 03:56 PM
01tl4tl's Avatar
replacement of ball joints, and maybe a few other things that are near being loose enough to replace (tie rod ends where the actual adjustment is made) should fix the prob
what were your camber readings?
I run negative 1.4 and no signs of wear from that
Did have a toe wear issue when it needed an align again~
rare is the TL needing kits, I hear about rear being installed more often,
as it exceeds neg 2 degrees it will eat the tires
Old Mar 25, 2012 | 03:58 PM
01tl4tl's Avatar
rough roads, potholes, careless spouses curbshot,,,those all make alignemnt come off spec
Old Mar 25, 2012 | 04:41 PM
1st timer's Avatar
UB6IB9
i'm going to install the new tires and get an alignment, change the bad ball joints and then see what the readings are.
mugen_kid
Nov 13, 2015 10:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
PortlandRL
Sep 14, 2015 12:01 PM
asahrts
Sep 4, 2015 05:55 PM
