Throttle body question
What do you mean whistling humming problem. That part is for the IACV and is necessary to be there.
I figured that the slot needed to be there. A couple of weeks ago I noticed a humming noise coming from the intake. I had just put in a K&N filter so at first I thought that was the problem. I disected everything yesterday and could hear a whistling sound coming from the slot in the throttle body. When I put the intake tube on, the noise is more of a humming sound. I did make sure that the butterfly wasn't making the noise because it was completely close.
Its a normal noise, not a problem. Its part of the reason our cars have a few resonators on the intake.
The noise wasn't there after I removed the resonators which was 9 months ago. It just recently started. I'm wondering if it could be a carbon build up in the air path which is causing the noise. It's embarrassingly loud. I may try to remove the IACV and clean it.
You didnt hear it, or you have a hole/leak in the air system because ALL 2nd gens have it. Its a characteristic of the motor. Its not a buildup or any thing. Adding the K&N may be why your hearing it more as its allowing more flow/noise.
The K&N has nothing to do with it because the sound is just as loud with just the intake pipe connected to the throttle body - without the other end connected to the air box
If it's machined in, it was there before you had the noise. Something else has changed, I doubt the slot is the problem. Something else You've done is likely the issue.
Well all i can say is your car made the noise before hand. You dont have a problem because all of our cars make it.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
